View unanswered posts | View active topics It is currently April 29th, 2026, 2:53 am
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Lower bulkhead and toeboard - corrosion
Post Re: Lower bulkhead and toeboard - corrosion
about tub...
Translated 1 on 1 in Dutch it is called a coach :roll: :roll:
June 2nd, 2015, 12:11 pm
Looks like it has already been replaced once - or something as that line of weld on the RH panel isn't original. Rip it all out and start again like others have said. Check the floor panels are OK, as when I did mine, they were shot too.
June 8th, 2015, 7:27 pm
well done...
Nice weld along sill and A post.. Looks like a good job from here.... (sitting in my favorit chair)
June 8th, 2015, 7:34 pm
Hi, is it possible to replace the complete inner and outer toeboard without removing the body shell from the chassis or taking the engine out?
I have a two post ramp, and the chassis is fine.
Regards Andy
June 11th, 2015, 12:17 pm
Regards Andy
No
John Jordan
June 11th, 2015, 2:37 pm
Regards Andy
yes, but i wouldn't recommend
June 11th, 2015, 6:27 pm
