View unanswered posts | View active topics It is currently February 3rd, 2026, 9:55 am
Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Cloverleaf 1925
Post Re: Cloverleaf 1925
thanks
May 19th, 2015, 8:40 pm
with Geo's help i cleaned the rust out of the brakedrum on the gearbox...but helas we forgot to photograph the thing spinning on the lathe... :oops:
May 23rd, 2015, 2:25 pm
We finaly got the rearaxle hooked up to the gearbox. Thanks to Geo's help to clean up the gerarbox brakre drum. We had to loosen the axle to get the flector fixed. For the first time we did get the car out on it's own wheels after been on stands for a very long time.
June 2nd, 2015, 11:26 pm
Finaly getting there at last... Great job sofar
June 3rd, 2015, 6:16 am
strange coincidence my left rear wing was rotten and badly repaired by one of the previous owners. And therefore it didn't fit well. Last weekend i found a NOS left rear wing in superbe condtion. Great to find such an 90 years old part for a very reasonable price. :D
July 10th, 2015, 10:49 pm
Any progress on this ?
December 27th, 2016, 6:53 pm
Hi Geert, no not much, hope to get moving again soon.
December 27th, 2016, 9:52 pm
After closing up 22 holes in the aluminium dahboard with aluminium rods rivited in and polishing of all oxydation. It was time to "'bouchonner". This is the making of little circular scratches as decoration. This is done by a kork (hence the name from bouchon) in the drill press. First make a jig on your drill with lines drawn at a desired distance. You clamp a piece of wood along this lines and present the aluminium piece under the drill. Put some valve grinding paste on it then press the turning kork on it (not to hard). Then slide the piece half a just made circle and press again. The next circle has to overlap the first partly. An so on. The next row has to overlap the first partly but also ofset half a circle. It's like laying rooftiles. It's not hard to do but you have to concentrate because an error is not easy to undo. After the work your have to wash of the black dirt with kitchen paper drenched in petrol. But carefully to avoid scratching your work.
December 13th, 2017, 8:58 am
Keep up the good work! :!:
I really admire you.
Please don't give it up and respect the structural norms. :D
I've Been Wrong Before.
December 13th, 2017, 9:36 pm
Have at last found the solution for the badly repaired rear wing. The new one i found didn't fit and had a different shape. :(
We had already had to straighten the chassis rear member. I think the car had an accident and the did alter/repair the wing to fit again. Now the chassis is straight the wingshape was wrong again. It was sitting 3 cm lower then the running boards. So i cut a slit in the wing and welded a part in. The fit is ok now. So i can weld up the rest and clean it.
April 28th, 2018, 8:26 am
Users browsing this forum: No registered users and 312 guests
