View unanswered posts | View active topics It is currently April 28th, 2026, 3:53 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 42, 43, 44, 45, 46, 47, 48 ... 105  Next
 Make Your Own ....2CV.... 4x4
This is one of the oldest 1-2-Spark ignitions around... (suppose it is the test-unit from Mark 4x4 Superfinn..
Take good care of it.... will write at the 1-2-spark topic how to make the pickup at the right spot...
April 28th, 2015, 6:48 pm
better fix that print plate it will be bashed around in the box like this.
May 3rd, 2015, 8:17 am
Upgraded to the Production Model.
May 3rd, 2015, 10:17 am
Eh for Pete
Drive shaft boot number is GKN Spidan 26005
for early golf mk 1
May 3rd, 2015, 8:58 pm
Obtained an AX air filter from the scrappy.
Has a larger Element than the 2CV, which always seems to be very dirty.
Fitted and can now more easily access the Dip Stick and the Oil Filler Cap
May 5th, 2015, 3:28 pm
Eh Pete if i get it correctly you have a small dia inlet hose to the AX filter
i noticed off road that a long tube like this may restrict air flow
it may be good to up the tubing dia
May 5th, 2015, 8:26 pm
'Restricts air flow'?
That's a polite way of saying that putting a vacuum cleaner hose in the intake plumbing plays havoc with the carburation... :roll:
May 5th, 2015, 11:40 pm
Waterproof USB Socket.
Bulkhead Gland (Size M25) £2.00
From Ebay £2.50 incl p&p
Rempve the rubber support
Blanking plug glued into the cap
May 6th, 2015, 11:31 am
at that price we are probably better of getting the beer in!
my pony doesn't have any cables
can you jump start it using that plug?
May 6th, 2015, 8:09 pm
If you wait 3 days to let it charge... :? :? :?
May 6th, 2015, 8:23 pm
Users browsing this forum: No registered users and 15 guests
