View unanswered posts | View active topics It is currently June 29th, 2025, 5:33 pm
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 534, 535, 536, 537, 538, 539, 540 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
Can't you write an email, use Google to translate it, and ping it over them them? I'm guessing they have a tech.dept. and an email address.
April 19th, 2015, 4:05 pm
Are you running it in a shed far away from the electricity closet??? Then there's to low current to keep the motor running (especially when it needs to come in when it is already filled with air). Take it close to the electricity closet (where the power cable comes into your house and try it there) probably it will run fine there....
When it does you need a delay valve, when the motor runs decent after about 10 seconds the valve closes and only then the pressure is build up...
I had the same long time ago...
April 19th, 2015, 4:08 pm
Its not that far away LPGO from the mains into the house, I use the same socket to run my mig welder - the valve seems to be working ok when I let the air out of the compressor the motor cuts in OK
April 19th, 2015, 4:31 pm
join and have an ask on here http://www.mig-welding.co.uk/forum/ plenty of sparks and people that use and fix them every day, theres a few eejits that know fuck all that'll chip in with drivel but youll be able to work out who knows what.
April 19th, 2015, 7:56 pm
Good thinking Sean have joined and posted :D
April 19th, 2015, 8:17 pm
Collected this today; 5ft square Illuminated garage sign. 2 of us struggled to lift it! :roll: :lol:
April 25th, 2015, 8:22 pm
Great Buy
April 25th, 2015, 8:31 pm
That'll look mint on your house.
April 25th, 2015, 8:39 pm
If I had a house, I agree, it would look mint!
April 25th, 2015, 8:42 pm
What are your plans for it? You want to get yourself an apartment style shag pad or summat, and illuminate it with that.
April 25th, 2015, 8:44 pm
