View unanswered posts | View active topics It is currently November 19th, 2025, 7:34 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 77, 78, 79, 80, 81, 82, 83 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
old-fashioned welding the pick-up, because I used a "thin" flywheel with no room for a hole & tapping a bold to it - so no fancy solution for the pick-up unfortunately
March 24th, 2015, 11:41 pm
Post Re: 1-2-spark
it looks good, but I felt it is too thin. it will vibrate.
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
March 25th, 2015, 11:52 am
Post Re: 1-2-spark
+1
March 25th, 2015, 12:23 pm
Post Re: 1-2-spark
your feelings are correct - this prototype is 1.0 mm stainless steel - though the motor is not yet build in and running, but I do not have the trust that it is stable enough :oops: - I will lasercut another one with thickness 2.0 mm and see how that one will do. Unfortunately there is no other place on the motor and/or gearbox nearby for another fixation.
I will keep you posted of my results
March 25th, 2015, 2:42 pm
Post Re: 1-2-spark
@Bracket
Like
Idea...
Either bend a 4mm edge along the side (away from carb)
weld along the under side a "stiffner"
March 25th, 2015, 3:21 pm
Post Re: 1-2-spark
This is myidea too
March 25th, 2015, 3:47 pm
Post Re: 1-2-spark
How about that place?
I have tested, both VR and HALL -sensor read well the original 6mm timing hole, no lost signal even 8000RPM, haven't tested more yet. With that, the timing hole is about 90 degrees BTDC.
Bracket is mounted by these nuts, long enough to work at crankcase nuts and still there is enough thread to mounting bolt.
Good enough for Megasquirt, don't know how it could work with 1-2-spark (sorry Geo, couldn't resist) :lol:
March 25th, 2015, 4:49 pm
Post Re: 1-2-spark
No problem Jasu...
1. the sensor @ 1-2-spark needs settle at 45 degrees...
But I could problably cure that by turning the flywheel 1 bolt at the crankshaft.. the flywheel is bolt by 5 screws
360/5 = 72 degrees, 90 - 72 degrees = 18 degrees no good either..
2. I don't like the idea of sensing at the front of the flywheel. For instants the crankshaft of my old 2cv floats (has axial play) for about 3 or 4mm; the the sensor gap would go from .5mm to 3mm.. This is not good either (especcialy when starting the engine), so this is why I am taking it at the top of the flywheel insted..
Just curious is it possible to put the mounting at the other side of the engine???
Just another thought... Everybody is talking about a unbalanced the flywheel with the pickup, but I am sure there is more stress at the crankshaft putting a belt driven compressor to it....
March 25th, 2015, 6:03 pm
Post Re: 1-2-spark
Thats true about end-play on crankshaft, it can be problem if it is too much...
About belt driven things, the stress what they make is a different issue than unbalanced flywheel...
March 25th, 2015, 6:21 pm
Post Re: 1-2-spark
very nice fitting , i like the logic of using existing carb mounting studs
10 out of 10
pony
March 25th, 2015, 10:34 pm
Users browsing this forum: No registered users and 19 guests
