View unanswered posts | View active topics It is currently July 18th, 2025, 4:35 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 276, 277, 278, 279, 280, 281, 282 ... 400  Next
Fed and Watered and on trailer ready for Green Road tour of the Ardenne Region.
March 12th, 2015, 3:36 pm
Sorted the no charging, fuel gauge, indicators and the like, after they failed last night. Just a blown fuse. Went or a spin with the roof half open and for the first time got wacked on the head by the frame I'd not secured lol!
March 12th, 2015, 7:24 pm
bought some bits and pieces to get the blue one back to life, and start on the Dyane ...more a theoretical start than any actual metal cutting.
March 13th, 2015, 9:09 am
Drove it over the Downs and for the first time since before Christmas it went up them @ 30mph+ in 3rd instead of 15mph in 2nd, hurrah.
Mike
March 13th, 2015, 7:46 pm
It was rather grand to see it again. I always felt it suits the rural setting up there.
March 13th, 2015, 10:04 pm
This evening I changed a middle drive shaft boot for the first time. Managed to do it whilst the other half cooked tea! Wondering now what I've missed because it appeared to go a bit easily...
March 13th, 2015, 10:59 pm
Which end did you remove the drive shaft from? I've always done it by taking it out of the hub, but I wonder if it's easier to take it off the gearbox end.
March 13th, 2015, 11:25 pm
Yes I took it out of the hub too. I did look up various posts on here and other places and the hub end seemed to me to be the most popular so I went with that one. I also thought that access would be easier rather than reaching in over the wing and I would be able to better fight the boot over the splines on the bench. A greased cone from a cut up plastic bottle was 'made' for that bit.
I am very happy so far that this went well. Good also for 10 year old helper to see a job go well without any cursing! Though, I'm ready for it to not go as well when I have to do the other car that needs the full set of boots on both drive shafts and both track rod end boots as well. I can't really picture how the t-shaped boot goes over...
March 14th, 2015, 12:55 am
So that you don't lose any credibility with the trainee, steering ball goes into the gaiter first, then you start to feed the 'tube' part of the gaiter onto the (cleaned & greased) track rod end housing.
As long as the slot in the underside of the housing is aligned with the ball, it's all over in a moment, so you might want to drag things out to make it look difficult... :lol:
March 14th, 2015, 1:09 am
ken wrote:
So that you don't lose any credibility with the trainee...
Might be a bit late for that though. :?
Thanks for the advice.
March 14th, 2015, 1:38 am
