View unanswered posts | View active topics It is currently June 19th, 2026, 12:42 pm
Reply to topic  [ 10 posts ]
 clutch release bearing (just in case)
Post clutch release bearing (just in case)
Just in case I've got it wrong - When I put my foot down on the clutch pedal (Race car, yes the one on the page header) I am getting an awful sound from the gearbox (going in and out of gear ok) I've ordered from Roy today a clutch release bearing so hoping this is the correct part to fix the noise!
Also how do I check the 'free play' in the cable
Thanks
Simon
February 25th, 2015, 9:53 pm
Post Re: clutch release bearing (just in case)
take the outercable near the point where it's going into floor and pull, if it comes out to far there is to much play. I can't tell how much cm is the right free play.
February 25th, 2015, 10:54 pm
Simon,
use one finger to press the clutch pedal down.
There should be between 20m to 25mm movement without much resistance, after which you'll need to use a lot miore pressure to depress the pedal further.
p.s. If the release bearing is worn, best check the clutch diaphragm 'fingers' as well.
If they've got a deep groove in them, it might just be time to go for a complete clutch kit...
February 26th, 2015, 12:37 am
Thanks Ken & ALZ57
February 26th, 2015, 9:36 am
oh well the clutch release bearing doesn't seem to have been the issue, have fitted a new clutch kit inc clutch release bearing, although at first i thought was all good now seems to be more noisier, so i think its the gearbox input shaft bearing needs replacing - is this a do it yourself EASY job or has it got to a specialist?
April 2nd, 2015, 10:13 pm
its easy but....
you have to take the gearbox down to its component parts as its pretty much the first thing fitted when building a box or the last out when stripping it. If your not confident stripping the box or time is tight time to give someone a call.
April 2nd, 2015, 10:31 pm
Hi Sean, I've got another box to put in the race car for Brands next weekend I hope that one is better than the one now sitting on the garage floor, I think I will get someone to look at it
April 2nd, 2015, 10:52 pm
My van makes a chuffin' squealy racket when I'm releasing the clutch to pull away/between gears. Initially I thought thrust bearing, but I'm now wondering if it might be the input shaft bearing.
Could anybody please advise, before I spend on something I don't need?
Many thanks
April 3rd, 2015, 10:26 am
It can't be any gearbox bearing, because when you press the clutch down, everything on the gearbox (when standing still) doesn't rotate...
What condition is bushing/needle bearing on the crankshaft, where the input shaft goes? If there is bushing, and it is dry as Sahara, it can make quite strange noise...
April 3rd, 2015, 11:06 am
new gearbox fitted today (I know I know) and all is quiet - the gearbox I have taken out has done 1 x 24hr Race let alone anything else it did before - even after fitting the new clutch release bearing the gearbox was getting annoyingly loud!
April 3rd, 2015, 3:56 pm
Users browsing this forum: No registered users and 212 guests
