View unanswered posts | View active topics It is currently June 19th, 2026, 12:55 pm
Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 Suspension Travel
Post Re: Suspension Travel
126.056 are rear dampers, 126.076 are fronts, so as long as the fronts haven't suffered any damage from being used as bump stops on the rear, it's worth refitting them correctly.
Guess this car has undergone a chassis change since Jeroen put it together, pity that whoever did the job hadn't got much of a clue. :(
adam_d wrote:
ken wrote:
Adam,
if front dampers had been fitted to the rear, it might be worth checking that the front end hasn't got rear dampers fitted...
Any service history with the car?
Swapped the rears to Monroes last night and tried it out tonight, much better. The Lips that came off are numbered 126.076. I have checked the front ones just now, and they are numbered 126.056. I guess that means they are rear ones?
If so, would it be worth taking the Monroes back off and putting the Lips back on in the right places? From reading around, they seem to be better than the Monroes?
February 19th, 2015, 12:02 am
Users browsing this forum: No registered users and 211 guests
