View unanswered posts | View active topics It is currently June 19th, 2026, 12:43 pm
Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4
 AMI 8 trouble starting + heater controls
Post Re: AMI 8 trouble starting + heater controls
Matt where are you? I have a few sets of ignition kicking around if you want to play with them. There are differences between the weights & cam assembly from different engines, bigger weights on M28 engine and the cam has a 'blunter' profile (thanks to Ken for pointing this out on another thread) and a shorter dwell. The bits don't mix! ;)
Mike
January 24th, 2015, 3:54 pm
I work in chessington. And live not too far from there too
Cheers
Matt
January 24th, 2015, 4:11 pm
Well the points are back in and timed and dwell set up
It seems to have lost a little mid range torque . I guess the advance curve is slightly different to the 123
I will see how it starts in the mornings
The plugs are back out to .7 mm
March 5th, 2015, 1:06 am
Its been 1st time starting now for the last few months since the points went back in
so it looks like the 123 was causing the problem
June 22nd, 2015, 5:20 pm
Users browsing this forum: No registered users and 213 guests
