View unanswered posts | View active topics It is currently August 16th, 2025, 5:24 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
jasu wrote:
How about cable -operated 6v starter..?
Yes, I know, someone says it won't last, but with my own experience, it works well. Have used over 10 years on my 12v Dyane, with 9 winters, and it started well at more than -30C°...
Only disadvantage what I have found, the brushes wear quite fast, needed to replace about once in every year when driven about 30000-50000km/year... :roll:
For the first start I did about the same, feeding 24volt to my 12 volt starter motor... Don't know if 6 volt startermotor will do the trick.. Cranking it by hand I can hardly turn it with a 30cm wrench..... and now I'm happy with the startermotor shown above...
January 6th, 2015, 11:44 pm
Yes it does. Also it is capable to drive on 4th gear with 6 volt start at 12 volt... :lol:
January 6th, 2015, 11:48 pm
Thanks lpgo. I will see what I can find :)
January 7th, 2015, 1:40 am
If you do find one let me know where!
January 7th, 2015, 10:51 pm
Certainly no reduction gear in any 2cv starter motor.
6 volt 2cv starter motors are commonly used on 12 volts by 2cv crossers.
Pony wrote:
as far as i am aware only starters for diesel cars have a reduction gear inside them!
pony
January 8th, 2015, 10:36 am
Valeo Gears!
January 13th, 2015, 3:21 pm
subarupete wrote:
Valeo Gears!
Sub_Pete YOUR MY HERO... I was thinking about dismanteling my new startermotor but now I don;t need it anymore... (draining the garantee down the bin) Now this is what the diffrence makes.. just as my starter-motor-guy told....
And I still don't believe a 6 volt starter motor (on 12 volt) will turn a 1200cc Beamer.... This is not a 600cc engine you know and offcourse I won't try it either...
January 13th, 2015, 6:15 pm
A 6 volt Traction starter working off 12 volts turns the Traction engine. Not too much bigger in size of motor
January 13th, 2015, 6:37 pm
Maybe a difference in compression?
January 13th, 2015, 7:26 pm
als with a traction it has to 'push' only 475 cc (1900/4) at a time with low compression (as subarupete mentioned) also the tooth and mountingpoints of a traction are probably different, so tha chances this will work are pretty slim.
I guess the way to go like Joolz and LPGO do, get yourself a decent startermotor with buit in gears!
greetzzzzzzzzzzzz
bitten by the Citobug...
January 14th, 2015, 8:34 am
