View unanswered posts | View active topics It is currently June 19th, 2026, 6:49 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Ok I need to buy a starter motor?
What was the deciding answer?
Valeo only or cheaper alternative?
Is the valeo one used the standard part No for the 2cv6 or a cross over part someone has found that fits but more torque?
found this 1.4KW?
http://www.ebay.co.uk/itm/Brand-New-Sta ... 566032c3fe
January 5th, 2015, 8:39 pm
I had the same problem, went to the local starterengine dealer. I now have a very good one. Don't now if it is the same as yours the guy said it has a reduction gear build in...
My video's are made with an old 2cv battery, a standard 2cv starterengine (tried several) doesn't even turn the engine over...
found this 1.4KW?
January 5th, 2015, 11:38 pm
Does yours have any part numbers on it a brand?
January 6th, 2015, 11:19 am
And a picture? I've not seen a reduction gear type for a 2cv.
January 6th, 2015, 1:36 pm
Online
I think! the Valeo have an internal Epicyclic gear
January 6th, 2015, 2:34 pm
Yes, this one has it too... Found the bill, nothing much on it. I paid 77,- euro for it...
D6ra43t, but even the Chinese one are carrying this number.. Will take some pics later on...
The only thing is... 1 cilinder didn't have much compression, didn't test it after I set the valves, but as said, none of the (used) 2cv starter engines could turn the engine and this one does it with ease....
January 6th, 2015, 7:47 pm
I've used a big old 2cv starter, need to use a different one as its isn't really strong enough to turn it over but does trouble is with a small battery and shit starter I'm always nervous it won't start..
January 6th, 2015, 9:56 pm
as far as i am aware only starters for diesel cars have a reduction gear inside them!
pony
January 6th, 2015, 10:15 pm
Here pics of my startermotor I think there are planetairy gears in there...
sorry just some shots with my phone...
And no I am not going to dismantle it to investigate ;) ;) ;)
January 6th, 2015, 11:11 pm
How about cable -operated 6v starter..?
Yes, I know, someone says it won't last, but with my own experience, it works well. Have used over 10 years on my 12v Dyane, with 9 winters, and it started well at more than -30C°...
Only disadvantage what I have found, the brushes wear quite fast, needed to replace about once in every year when driven about 30000-50000km/year... :roll:
January 6th, 2015, 11:30 pm
Users browsing this forum: Google [Bot] and 190 guests
