View unanswered posts | View active topics It is currently August 14th, 2025, 6:19 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 43  Next
 1955 Traction Avant 11cv
Thanks for that - I have seen a lot of people take off the original but I just painted mine yellow, so want to keep it and at least it will be extra cooling as I have heard the Traction suffers from overheating.
So electric fan, temperature gauge and waterless coolant will hopefully combat this.
Ian
December 10th, 2014, 3:02 pm
Original distributor found on Le Bon Coin - very happy as it was €30 cheaper than any new replacement I have found.
Matches mine exactly :D :D
December 13th, 2014, 10:16 am
NOS is always better.. have had a lot of problems with modern reproduction rubbish....
December 13th, 2014, 12:16 pm
I think I have finally finished all the really dirty jobs. I raised the car up on axle stands so I could get underneath and get all the crap off the bottom of the floor pan. Also so I could finish off the welding on the replacement front floor panel.
Lots of dust but now I can clean the garage and hopefully it will stay a little more dust free :?
I slapped a load of rust converter paint (Restom) on the panels and left it to dry.
I joined the V sections under the floor. They were slightly off but managed to create a small filler panel. Welded it all up and covered all the seams with a polyurethane seam sealant.
Inside I rust protected, primered and painted the inner floor that is covered with the seat cross member. I also seam sealed the welds and edges before putting the cross member back on.
So the next job was repairing the seat cross member. I had to remove this to get to the floor panel. So I had to cut the flanges off and then hammer chisel the flange and spot welds from the floor. So will a little bit of angle I made up some new flanges and after lots of marking up (and several failed spot weld attempts..... all good practise :D ) I fitted it all on the bench.
It fitted straight in and I spot welded (punch hole then enlarged to 8mm and used a spiral movement on the weld) the cross member to the floor and also to the sills of the body. It seems pretty firm and inspection underneath showed the penetration of weld so I am happy now and getting a little more confident with this welding stuff ;)
In between the big jobs I always have a side job on the go, normally when it requires a bit of paint spraying and drying. I really needed a new rear number plate light unit. I tried everywhere but none were in stock and at €100 theses were not cheap. So renovation and rectification was the only thing to do.
December 15th, 2014, 12:15 pm
All the plastic was gone and the electrical fitting were awful, but with a little micro sablage and wire wheeling it all comes up pretty well.
Painted black (for now) on the outer and chrome inside (for refection) the units are looking good. I made up a template for the plastic lenses and made these from an old storage box (I think it was old) and these fit quite well. There is a section that lights up the inside of the boot, I assume when the boot lid is open it lights up the area, I have left the lens off this as I think the heat of the lamps distorted the old lenses, will try anyway and see if it is OK.
Back on the bench to do some clean jobs - Installed new fuel sender and filter unit.
I am a bit concerned on whether I need the little plunger unit on the sender (circled in red). The new unit I received form Jose Franssen did not have this. I had a look at transferring it over and it is do-able but if it is not required then I will leave it off as there new unit is not the best i.e. the lever is not free falling very easily. Once I have the system up and working I might try the original unit back in as it looks to be in good order.
Off to Auto Distribution to get more weld seal and finish off the underside and inner floor panels. I will prime it and then paint with chip seal. Then get the car off there axle stands and back onto the hydraulic lift. There is a plan to this, somewhere ;)
December 15th, 2014, 12:57 pm
Is the 'plunger' a damper for the float arm? If "the lever is not free falling very easily" on the new one perhaps it isn't needed. Just thinking out loud.
Mike
December 15th, 2014, 4:29 pm
It is a damper, very nice design so I am reluctant not to use it. But yes the new one probably doesn't need it.
The old one had a nice cork floater too... I will see when I get the system up whether I need to change it out or not.
December 15th, 2014, 5:31 pm
So yesterday I started on the engine "properly" :D
I received my new gaskets for the piston barrels and duly inserted them and measured the tolerances and all seems good. I then decided to fit the head in place before flipping over the engine. In the 15/6 English manual it says to do it this way and it makes more sense. Although I think I may have a job flipping it over with the extra weight :(
So now I need to prepare the head. My new coolant tube arrived along with new core plugs. So with a little more cleaning I fitted the pip easily pointed the holes downwards and then sealing (glueing) each end with ultra blue. I also flared the end of the pipe at the water pump end, hoping it won't move too much.
And fitted all the new core plugs that I had to remove to get rid of the coolant pipe. Slightly easier than removing them :lol:
And of course in between these jobs I am finishing off the painted of the floor panel I replaced as well as getting the underneath finished off.
So after sealing all the seams and the edges with polyurethane weld seal I painted it all with rust eater and then primer.
Then a nice top coat of satin black just to make it tidy and for the underlay and carpet to sit on :) It is starting to look like a car again in side.
December 17th, 2014, 6:44 pm
So back to the head preparation. I had read about the valve seals needing to be installed just below the split collets and in my gasket pack there were new valve seals. I cannot remember seeing these before when I sent the head to be cleaned, surfaced and new valve seats fitted. They also fitted the new guides and springs. I have a sneaky feeling they did not bother with the seals. I checked number 1 and was correct nothing.
So after putting together a Heath Robinson rig to remove the valve springs I inserted the new seals just under the split collects - so an hour or so just getting me back to square 1. Only close inspection of the head, I don't think the company actually did anything other than install new valve seats - I am pretty annoyed but if I went back the Frenchies would just sling their arms in the air and "c'est la vie" :evil:
Here is what the head looked like when I got the car
I stripped down the rocker shaft
And prepared the head for docking :D Nice new gaskets and placed the push rods in place.
December 17th, 2014, 7:17 pm
On with the rocker shaft all cleaned up. Took some time cleaning out the shaft and making sure all the oil passages were good - I have read a lot on this subject lately. :?
Looking more like an engine - the cam shaft pulley is fitted and the valves seem to be going up and down in some sort of sequence.
And now the upturn of the engine - bloody hell it is heavy, but luckily my wife was passing the garage and I whistled her in :lol:
And while all that was being done my under floor had a coat of primer and is drying nicely. Stone chip will be adorned tomorrow and then I can get the car back on the lift and off the axle stands.
December 17th, 2014, 8:58 pm
