View unanswered posts | View active topics It is currently June 19th, 2026, 12:46 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Gobi project
Post Re: Gobi project
citroenboat wrote:
Great videos Henk - I see the lawn mover lever lifts the rear shift rods to engage, does it use rocking levers, to reverse the direction of the movement, opereated by the front shift rods or what? I think I understand what is going on but can't quite see...
Geo
Nice piece of enginering Henk, looking good, but it can be done much easier... transfer from left to right...
makes a nice cliffhanger... p.s. take a look at my Sahara pics; maybee you discover it...
found your Sahara thread on this site but there is not really a photo of the gearshift operation, where would I find it please?
Thank you.
Soon i will take the shifter to its pieces for painting. Then i will make detailed photographs and film how it works inside.
December 4th, 2014, 6:29 pm
:D
Mike
December 4th, 2014, 8:23 pm
Like+++
December 4th, 2014, 9:48 pm
Working on the gearbox. The rod clampbolts on the selector have a special model. To unscrew them, you need a special tool. This is a very expensive tool, so i made a cheap tool from a lever of a valve of the gasbottle. A little welding and it is possible to untight and tight the bolt to its torque with a torquewrench.
December 20th, 2014, 4:58 pm
working on the 4x4 gearbox. The rods need to be longer, so in the rods is tapered 8mm thread and 2cm inside. New rods M8 are made and now the gearbox can shift with the new selector. Only a seal is to be made.
December 20th, 2014, 5:05 pm
I could do with a lathe. Any one found a cheap supplier of 2nd hand ones.
December 20th, 2014, 6:04 pm
In the UK Myford, Boxford, Harrison go for upwards of £1500.
Need to be very careful when moving, most are top heavy, badly done the bed can twist.
see http://www.lathes.co.uk/
I have a Harrison L140 (onloan!) with Inverter to run it. The lathe is good size for car parts.
December 20th, 2014, 8:09 pm
I have a EMCO 7 found in the scrap and got it for free. After repair it s good enough for my job. Always looking for a better one.
December 20th, 2014, 9:22 pm
