citroenboat
 Re: Gobi project
Is that not Geo's Sahara having a rest there? Good use of a rusty one Henk.
_________________ Mike
| November 30th, 2014, 10:50 am |
AZL57
 Re: Gobi project
yes, we build it together. We came from the right were the suzuki is. But the car slit sideways hooked a wheel in the furrow and turned over. I hit my head a the rearview mirror... The door mirror ended up folded in front of the windscreen. Good base Henk. Did you reinforce the chassis? We welded the side plates in as in the citroen brochure Ici commence l'aventure.
| November 30th, 2014, 7:28 pm |
tweecv12pk
 Re: Gobi project
AZL57 wrote: yes, we build it together. We came from the right were the suzuki is. But the car slit sideways hooked a wheel in the furrow and turned over. I hit my head a the rearview mirror... The door mirror ended up folded in front of the windscreen. Good base Henk. Did you reinforce the chassis? We welded the side plates in as in the citroen brochure Ici commence l'aventure. Good evening azl57, Nice to meet you in the forum. I admire the sahara lookalike you build with your friend.As in your name i presume you have an azl 57. I drive an 61 AZ. ( AM-50-43) bleue glacier The chassis i use for the Gobi project is also 61 and is still french registered. Underneath the chassis is bad, so i have to repair this and weld reinforcments inside and outsidelike in the brochure. I started working on it last year. First i renovated two engines. Working on the car is not going very fast, because I have to figure out a lot of things and the goal is to build it very low budget.
| November 30th, 2014, 7:53 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
 Re: Gobi project
AZL57 wrote: Nice job Henk, have seen that before.... it took us 3,5 years. But it works fine... most of times though...  Is that young Geo at the right ? And you on the left ??
| November 30th, 2014, 8:05 pm |
AZL57
 Re: Gobi project
Yes you don't need glasses yet Geert  And yes i have an 1957 AZL and since a month or so even 2 AZLs 57...
| November 30th, 2014, 8:27 pm |
Geert
 Re: Gobi project
AZL57 wrote: Yes you don't need glasses yet Geert  And yes i have an 1957 AZL and since a month or so even 2 AZLs 57...  2 AZL's I know and a cloverleaf .... you lucky bastard !
| November 30th, 2014, 8:51 pm |
citroenboat
 Re: Gobi project
Sorry Fer I saw the picture somewhere else and only Geo was mentioned!  I'm just jealouse!
| November 30th, 2014, 11:32 pm |
AZL57
 Re: Gobi project
no problem..he was here before on the site
| December 1st, 2014, 1:33 am |
Robcap
 Re: Gobi project
Ilikitalot! At the moment enjoying my 2 wheel drive sahala lookalike(ish) 2cv. Might install a Quaife diff. Going to make a nice set of bumpers. Did some serious greenlaning in the Ardennes yesterday, and I'm hooked !!!
2VC 1980, Vert Embrun
| December 1st, 2014, 10:18 pm |
tweecv12pk
 Re: Gobi project
Robcap wrote: Ilikitalot! At the moment enjoying my 2 wheel drive sahala lookalike(ish) 2cv. Might install a Quaife diff. Going to make a nice set of bumpers. Did some serious greenlaning in the Ardennes yesterday, and I'm hooked !!! Quaife diff seems to be good. it is a limited slip diff. How to build an 100% lockable diff?
| December 1st, 2014, 11:08 pm |
