View unanswered posts | View active topics It is currently June 19th, 2026, 9:11 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Some porn for lpgo: http://andyw-inuk.smugmug.com/Motorcycl ... &k=84d4F2v
A lot of chains too
November 20th, 2014, 2:45 am
welded the inletmanifolds with plates to the exhaust, so now the inletmanifold is heated a little... and the carbs are rocksolid to the engine. I also welded some L profile to the exhaust and attached the exhaust to the rearside of the engine....
So next I need to take another 2mm of the spacer, I want to make a bolt for a 17mm spanner out of the 5 flywheelbolts in my mill (milling it 6 times turning it 60 degrees angle)..
so then the clutchplate will fit better. Now it is hitting the bolts of the flywheel/crankshaft...
After that it was playtime.... I started to synchronise my two carbs..... I like it a lot...
So it is almost time to put it in a car.... 8-) 8-) 8-) 8-) 8-)
November 29th, 2014, 10:10 pm
Online
Nice your neighbours will be happy too... ;-)
November 30th, 2014, 1:19 am
And what about "her upstairs "?
November 30th, 2014, 9:37 am
Till now the missis never complains, ;) ;) the neighbours I don't know... I don't haven an affair with them. :lol: :lol: :lol: :lol: :lol: :lol: :lol:
November 30th, 2014, 10:16 am
for further sychronising & adjusting the carbs : will you be using a double AFR-setup and/or a map-sensor on each inlet manifold ??
November 30th, 2014, 11:55 am
Online
You won't hear any of them shout a you anyway.... :mrgreen:
November 30th, 2014, 4:38 pm
double lambda-probe (if money allows) and a map-hose connected to each inlet-manifold and then to a T-piece going into 1 mapsensor (of 1-2-Spark)
December 3rd, 2014, 12:44 am
Or something like that. Type "carb sync tool" to Google, there you can find many more solutions for that...
At first, make sure there is same MAP-reading in both inlet, before that it is quite useless to adjust mixture. You can have correct mixtures, but still carbs aren't syncronized, then engine works well at idle but not when driving...
December 3rd, 2014, 4:57 pm
Online
Would color tune sparkplugs help in this?
December 3rd, 2014, 5:33 pm
Users browsing this forum: No registered users and 224 guests
