View unanswered posts | View active topics It is currently May 7th, 2026, 12:35 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
You've lost me on that one Jameswallace ? these are the factory fitting to the car, nice to keep...
Ive not posted a picture of my terrible main brake hard line Russell..... for good reason!!!
www.evilbens.blogspot.com
November 27th, 2014, 12:00 am
James,
I'd doubt that, as the quality of the original parts was usually much better.
For example, the original M7 bolts for mounting the body to the chassis had a tapered lead, which you won't find on any replacements.
Also, some knife edges nowadays seem to be made of monkey metal...
This is how all four knife edges on a recently rebuilt Dyane looked after 1 year/17,000 miles, so Jessie is putting the original '100,000 miles plus' pins back onto her car.
Also, what's going on with those rubber suspension 'end stops' on Ben's car, I've only seen original ones looking like that after they've been dosed with mineral oil or LHM for a couple of years... :?
November 27th, 2014, 12:10 am
Makes sense, so therefore seems like a v v good idea
Also, could a set of knife edges not be made initially on a lathe then machined to the correct shape, i assume (based on no knowledge whatsoever) that the 'modern' ones are cast?
November 27th, 2014, 12:50 am
The end stops are new and came from ECAS Ken.....
November 27th, 2014, 9:26 am
Have you done them up really tight and squashed them? That's how it looks in the photo.
November 27th, 2014, 9:32 am
Last edited by Tripyrenees on November 27th, 2014, 10:34 am, edited 1 time in total.
November 27th, 2014, 10:15 am
November 27th, 2014, 10:26 am
Not sure Russell... i've done them up so the cans don't spin and the threads sticking out with the boot on are the same amount as before...
Around four threads...is that right? I'm no expert with these vehicles....
November 27th, 2014, 10:46 pm
You should be able to turn the cans when there's no weight on the wheels, It's something you'd set up finally when it's on the ground.
November 27th, 2014, 10:51 pm
Thanks i will back them off a bit... the rubbers at the other end are the originals and look smaller and less compressed...
November 27th, 2014, 10:57 pm
Users browsing this forum: No registered users and 323 guests
