View unanswered posts | View active topics It is currently June 19th, 2026, 9:11 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Great work... I need to get more pics of my progress. Been doing more on the rest of the car to get mot done before engine swap..
November 4th, 2014, 11:40 pm
Online
springs of the 51/55 will not be strong enough for the heavy engine.
November 5th, 2014, 9:23 am
@Geo
An idea for adapter plate... Cut another in 3/4mm plug weld/edge weld as a sandwich.
I think Alu would be the best but £££ and welding may a problem.
November 5th, 2014, 11:54 am
personally I would not be concerned about the plate panting. On 1000hp drag cars the motor adaptor plates are only 6mm 7075 aluminium. I have made mine from 8mm 7075 as I found an off cut suitable. you could always add a stabilizer rod down the the chassis to control longitudinal movement?
November 5th, 2014, 6:25 pm
Cut a strip and weld it round the edge if you can.
November 5th, 2014, 9:16 pm
Today I milled my spacer.. The mookup was out of aloy but this one is out of steel...
First I did a little test if the 5 holes for the spacer where at the right spot..
after that I drilled all the holes in a 3 point chuck which rotates 360 degrees, at my milling machine..
Then I assembled it together with the flywheel which I drilled earlier..
At last a little video of the perfect fit of the spacer... ahum
http://www.youtube.com/watch?v=aWr4codS3AI
November 14th, 2014, 12:42 am
Great work
November 14th, 2014, 12:25 pm
Ditto - wot Pete said!
mike
Mike
November 14th, 2014, 1:01 pm
thanks guys, I'm doing my best... It is the first time using a mill (and lathe) but for me it looks alright. I noticed that the proper tools is half the job.. Luckely my secondhand mill came with a 3 jaw chuck and a 11mm cutter-drill?? it goes through the steel like butter and it doesn't wander off... So I'm very delighted with the result so far.. Hopefuly it works at 8000+ rpm like it looks right now.
November 14th, 2014, 1:21 pm
What sort/make of mill?
November 14th, 2014, 3:29 pm
Users browsing this forum: No registered users and 222 guests
