Russell
 Arm bearings
How do you get the inner arm bearings off? Ecas website says you need a special tool but i don't have one. I am happy to destroy it if that's the only way, I'd rather get it off without though.
| November 9th, 2014, 8:04 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2258 Location: Near Monmouth
 Re: Arm bearings
A solution...An OLD carving knife to move it a few mm. Make puller from 10mm studding and some 4mm Ms plate.
| November 9th, 2014, 8:22 pm |
2CViking
 Re: Arm bearings
Arm bearing tool. Attachment: 6156143099.jpg Use a chisel in between the back of the bearing and the resting face. Be careful not hitting the face distorting it. If you do, use a file to ''repair'' it. Or remove the bearing and grind gently a slot in the inner race. Again very careful not hitting the housing. Don't cut through but nearly, then split the inner race with the chisel.
| November 9th, 2014, 9:09 pm |
Russell
 Re: Arm bearings
Hmm, ok I'll have a go thanks but I'm thinking it'll probably be a case of grind it off. They're bloody expensive aren't they?
| November 9th, 2014, 9:47 pm |
AZS
Joined: December 22nd, 2013, 5:01 am Posts: 300 Location: Netherlands
 Re: Arm bearings
Not the best way, but i hammer them off with a chisel, or hammer them out with a chisel, in case of the arms. At the axle i hammer the chisel through the dust seal. If the bearings are shot, you could split them but i would never do this with re-usable bearings, replacements aren't that cheap, and probably rubbish quality.
| November 9th, 2014, 10:01 pm |
 Re: Arm bearings
selection of old screwdrivers and chisels acting like a wedge behind the the race easy does it one side at a time getting started often messes up the seal
| November 10th, 2014, 9:54 am |
Pony
 Re: Arm bearings
If the inner race is shagged Gently grind the inner race in a way that you can introduce a chisel into it, to finally snap the last section which is not ground thru i have done 1000,s Just do not over grind and hit the seal area Never bothered with a puller for this job
pony
| November 10th, 2014, 9:47 pm |
Russell
 Re: Arm bearings
Righto, so there's no secret easy way.
| November 10th, 2014, 9:56 pm |
AZL57
 Re: Arm bearings
as far as i can remember i tapped them of with a large copper drift. Alternating taps left/right..
| November 11th, 2014, 12:42 am |
