View unanswered posts | View active topics It is currently May 1st, 2026, 1:38 pm
Reply to topic  [ 4 posts ]
 Cylinder head temp sensors
Post Cylinder head temp sensors
Question for the tuners and possibly racers out there.
I have some old Plug Ring type cylinder head temp gauges That I'd like to fit, just so I can see what's going on for interest more than anything else.
As the plugs are inset a little the ring sensors won't fit unless I Dremel out a little space for the 'sticky out bit'.
I trust it's safe enough to do this, and I won't cause a crack stress riser as a result... :shock:
October 31st, 2014, 2:00 pm
Post Re: Cylinder head temp sensors
photo please
October 31st, 2014, 2:09 pm
Ok so cylinder head and spark plug recess
Ring sensor
So I would need to relieve just a little section to allow for the 'sticky out bit', it won't bend sufficiently to clear.
October 31st, 2014, 2:51 pm
You can trim the plastic to give clearance for the Spark Plug.
The plastic gives some strain-relief to the cable.
Make sure the hole fits the plug as a loose fit.
Mine got jammed on the threads of the plug and the cable got pulled out.
The plastic doesn't do much anyway, as the TC is "crimped in".
Got mine here, bit of a wait
http://www.ebay.co.uk/itm/Thermocouple- ... 3a70c319c4
October 31st, 2014, 3:46 pm
Users browsing this forum: No registered users and 91 guests
