View unanswered posts | View active topics It is currently June 19th, 2026, 9:11 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Try Namrick uk company for bolts
October 26th, 2014, 10:30 am
No hit when searching M11 :? :? :cry: :cry:
October 26th, 2014, 11:11 am
I have ordered some similar that loom to retain the 11mm shank as some are thinner there as stretch bolts. I would have thought the longer will suit those with thicker adapter plates, mine is 8mm but see some are up to 19mm so would need the full length of these bolts. Will update when they arrive with pictures.
October 26th, 2014, 1:40 pm
I have a feeling BX / Xantia / Zx diesel and turbo diesel have M11 threads
how about checking your local motor factor for info, as head bolts do come in so many sizes
additionally fiat punto heads have M9
pony
October 26th, 2014, 11:42 pm
Alternative Flywheel Adaptor
October 27th, 2014, 11:17 am
Not sure if these pages are a good reference?
http://www.thepembleton.org.uk/techpages/MG.shtml
October 27th, 2014, 11:59 am
M11 x 1.5 bolts for the flywheel you say, what you mean like these? ;)
October 27th, 2014, 8:43 pm
This evening it was lathe-time. Made some bushings???? for my gearbox... Normaly the holes in the gearbox are 11mm or even 14mm, so I brought this back to 8mm. So now I can line up the gearbox with the engine and drill the 4 holes at 8mm. I think I can line it up within 1/10 of a mm this way.. Should be enough to make it work...
Afterwards I can tap it up to M10 and put the Original M10 threat-pieces in it..
Pigs of the day... (They are mobil phone pics so that's why I call them pigs) :oops: :oops: :oops: :oops: :oops:
October 28th, 2014, 11:50 pm
Joolz you show off! Hopefully I have similar waiting for me at home. Half term family break so won't know until weekend ha ha. Big fingers crossed that someone at work has kindly modded my flywheel while I have been away! I can then look at fitting it together in the bench.
Anyone have a loom wiring diagram for the motronic? I need to strip everything unneeded from my loom such as abs, lighting, stand switch and so on as its a full bike loom from an R1100RT ABS.
October 30th, 2014, 6:16 pm
I can supply you a 1-2-spark (BMW loom diagram) ;) ;) ;) :D :D :D + 2 2cv carbs and your done...
October 30th, 2014, 6:38 pm
Users browsing this forum: No registered users and 224 guests
