View unanswered posts | View active topics It is currently June 19th, 2026, 6:23 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Thanks Harley, is that the same for the input shafts? Either LNA or visa?
October 20th, 2014, 9:43 pm
Yep, you need the input shaft to match the bell housing, either lna or visa are the same. Also lna/visa shafts have the same clutch splines as 2cv, gsa is different.
October 21st, 2014, 1:31 am
Also very important... Visa/LN(A) has the starter engine at the right spot....
I'm going to start with a A-type gearbox.. Looking at the racers in Spa, almost every racer had a A-type gearbox inside...... so they can't be that bad.....
October 21st, 2014, 7:27 am
Where could be the best place to source bellhousing and a shaft? Also what's the type A box?
October 21st, 2014, 12:41 pm
A type box the normal 2cv one?
October 21st, 2014, 12:52 pm
db78 where are you?
Boggy
October 21st, 2014, 8:17 pm
A types are all 2cv/Ami/Mehari.. I call it delibratly this way because it is mostly common to make 1 gearbox out of a 2cv6* and dyane 6/ami 8*.. This is the longest geared gearbox you can get with standard gearbox parts... Some older Ami 6 boxes are slightly longer but only have drums....
Then longer it goes..
LN *
LNA/visa */*
gs 1015
gs 1220/Ami super
GSA (5 speed) *
Axel 1229 (1300) 5 speed is the longest available...*
* I have lying around....
For my first run I will use a 2cv6 box... just to shake down and do a Dyno-run then I will think what would be best and put that in.... However I won't go for topspeed.. 0-100 in 2 gears would be fine.. 8-) 8-) 8-) I'm not sure what max rpm on a 1200 beamer is but maybee it is possible with an LNa box....
Ami super would give you the shortest bell housing but starter engine is at the wrong place..
so won't work....
5 speed boxes are to long and placing them above the front axle gives you lubrication problems at the rear bearings.......
October 21st, 2014, 8:50 pm
Boggy wrote:
db78 where are you?
Boggy
Northampton/wellingborough UK.
October 21st, 2014, 10:44 pm
Hi geo,
I am going to combine the ami super box with the bellhousing and inputshaft from the visa/lna, this way you have a short bellhousing and the startermotor at the right place. Should fit 1:1 to a 2cv engine, so if you have the adapterplate made, it should fit!
Keep on building!
Greetzzzzz
bitten by the Citobug...
October 22nd, 2014, 9:04 am
Hi Rusty
Are the gear ratios better on the "super" box?
Boggy
October 22nd, 2014, 9:16 am
Users browsing this forum: Google [Bot] and 195 guests
