View unanswered posts | View active topics It is currently June 19th, 2026, 6:02 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
How is it going with the Carb flooding? Have you tried using a fuel pressure regulator. (assuming you've not lady solved it)
October 6th, 2014, 9:27 am
I think I know the issue for it... Testing the engine I only had the carbs attached to the rubber mounting at the engine. Now when the engine was shaking the carbs shaked 3 times heavier so the petrol was flooded into the inletchamber flooding the carb...
At least I hope this is it, at the moment I'm working at the real adaptorplate so didn.t test it anymore...
October 6th, 2014, 12:05 pm
Post Jig saw time tonight.....
This evening I've started to drill, mill, jigsaw the real adaptorplate... It is made out of 6mm steel which I can later weld onto the 2 2cv engine mounts.... I will make a seame along the outer edge of the adaptorplate from 3x30mm steel connecting the Beamer bolt points to the 2cv bolt points... Hope you know what I mean...
Some pics of the day...
Next thing is to center the gearbox... so fingers crossed....
October 17th, 2014, 10:37 pm
Post Re: Jig saw time tonight.....
I know what you mean...
... just be sure not to drop that slab of steel on your toes, please. :lol:
October 18th, 2014, 12:05 am
Online
Looking good, and it won't bend.
October 18th, 2014, 9:49 am
been along time since i last posted but i am making progress slowly. motor plate made, crank/flywheel spacer in the making.
October 18th, 2014, 8:29 pm
Mine has started getting mega over run recently.. a bit of playing about suggests the throttle bodies may need balancing.
@db78 you'll need to angle your throttle bodies outwards to clear the discs and callipers!
October 19th, 2014, 6:51 pm
@little Louis... I randomly picked 2 2cv carbs and let the engine run, it was a great relieve how good they iddled the engine, without any synchronising.... so it can only getting better (I hope).. I will synchonise them with the pressure sensor of 1-2-spark....
@ db 78 what a spagetti of wires on a Original BMW wire-harnass... I think i wil have about 8 wires going to the engine when I'm finished...
October 19th, 2014, 8:27 pm
The wiring will be looked at before fitting, plan to run it on the bench first.
Throttle body angled spacers are on my fabricating list.
Have also just got a GSA 5sp gearbox. Need to source a bellhousing next, I believe an LNA one?
October 20th, 2014, 10:48 am
That's right, visa or Lna are shorter, you just need to machine slots for the disk brakes.
October 20th, 2014, 9:18 pm
Users browsing this forum: No registered users and 191 guests
