View unanswered posts | View active topics It is currently April 27th, 2026, 10:10 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 105  Next
 Make Your Own ....2CV.... 4x4
I love this car!
August 2nd, 2014, 9:00 pm
Made cover for Engine ++ sound insulation.
Ready to go to France...
September 6th, 2014, 1:29 pm
Had a good 4x4 (long) weekend in France.
Result of improved front suspension, makes one try harder with the result....
Broken mountings for the front diff..
September 22nd, 2014, 1:47 pm
Other Bits damaged.
Oil feed to TBox leaking, new pipes that are really oil proof required.
Bent Gearbox mounting (5mm angle).
September 24th, 2014, 5:19 pm
You did a great job bending all this stuff...... did you do some jumpes on full power??
September 24th, 2014, 5:51 pm
Some steep climbs with rocks, to Fast as per usual.
But looking at the welds, they are bad,
I did them with last of the Gas and the end of the wire reel not feeding properly.
Plan to mount the front box with four mounts as it seems to get more movement/stress then the rear.
September 24th, 2014, 6:29 pm
Strange I would bet the rear would have more stress than the front.....
September 24th, 2014, 7:01 pm
The current job is to build a new Gearbox mount in 3mm steel and Thick wall tube, as 2mm steel and exhaust tube are not up to it...
Jobs done
After some more "Espionage" ;) in France, have added some Gussets
September 26th, 2014, 1:12 pm
Revised Front Diff Mounting...
October 4th, 2014, 1:57 pm
Diff now refitted..
October 5th, 2014, 4:58 pm
Users browsing this forum: No registered users and 22 guests
