View unanswered posts | View active topics It is currently November 20th, 2025, 3:06 am
Reply to topic  [ 5 posts ]
 Multimeter question
Haggis Muncher
Post Multimeter question
I splashed out on a new multimeter that can measure rpm, dwell angle etc as my old one packed in, but it only goes as low as 3 cylinders. Can i use the four cylinder setting and then double/half the results or something like that?
August 5th, 2014, 10:57 pm
Post Re: Multimeter question
yes thats what i do, dwell should be 53* on the meter set for a 4 cyl.
August 6th, 2014, 8:25 am
Haggis Muncher
Thanks, Sean.
August 7th, 2014, 2:16 am
Haggis Muncher
Dwell angle reads 50, so the points gap is too wide?
Also, the rpm reading was over 2000 at a fairly fast idle. Would I be right in thinking I halve the results because this is a wasted spark system?
August 7th, 2014, 4:55 pm
half the rpm, 2000 is pretty racey when your standing looking at it. 1000rpm would be a fast idle
when i set dwell its when the engine is running the engine will idle happily for 10 mins with the fan off - plenty time to set the dwell and the timing . just loosen the points screw and move it gradually with a flat screwdriver on the adjusting tang.
remember its dwell then timing
August 8th, 2014, 7:55 am
