View unanswered posts | View active topics It is currently July 21st, 2025, 6:12 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 241, 242, 243, 244, 245, 246, 247 ... 400  Next
Great Tour de France today :D
Here was our little set up at the end of our road :D :D
Imagetdf1
Imagetdf5
Imagetdf2
Imagetdf3
Imagetdf4
July 23rd, 2014, 7:20 pm
Very nice setup, with a soupçon of sponsorship from Cochonou there, if I'm not mistaken.
Also looks as though the weather for the Tour is back to being as good as it was for the Grand Départ in Yorkshire... ;)
Ken
July 23rd, 2014, 9:45 pm
Ooh Ken - are you suggesting that someone might be having a bit of self aggrandisement during the tour? Surely not!
July 23rd, 2014, 10:03 pm
A Little Video
http://youtu.be/9XY2jgREaa4
July 23rd, 2014, 10:43 pm
On commencement of exhaust fitting shenanigans, found the petrol tank was leaking, so gave up and drank fruit cider instead. Tank looks to be leaking from above, what's the most likely culprit?
July 24th, 2014, 12:45 am
the bit of pipe at the top of the tank is a common problem from what i've read. I think fixing it involves dropping the tank.
July 24th, 2014, 12:50 am
Yeah, if the car still runs you're still doing well. Empty the tank so it's manageable and it's not a bad or hard job to do. Simply drop the tank, replace the pipe on the sender and refit the tank.
July 24th, 2014, 1:07 am
Thanks chaps - need to run it a couple of hundred miles to use some of the fuel first!
July 24th, 2014, 11:23 am
Unless the tank has a drain?
July 24th, 2014, 11:24 am
No Drain unfortunately......
July 24th, 2014, 11:29 am
