View unanswered posts | View active topics It is currently June 19th, 2026, 7:14 pm
Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Oil leak
Post Re: Oil leak
Joe,
once you've got the wings off, clean the crankcase using brake cleaner (posh option) or a rag soaked in petrol (cheaper option), then run the engine, which should help you spot where the leak is.
Btw, if it does turn out to be the oil pressure switch, it's not necessary to remove the engine cowling to change it.
Ken
Joe wrote:
I appreciate all of this info guys, I need to re-set the valve clearances and clean the oil cooler on my day off so I'll strip a bit more off and take a proper look when I do that. I'm hoping it's the cheapest possibility!
July 17th, 2014, 11:41 pm
Post Re: Oil leak
Furthermore you can cover the crankcase with talcum/baby powder to spot the leak. ;)
I've Been Wrong Before.
July 20th, 2014, 7:02 pm
Post Re: Oil leak
Interesting, never heard of doing that before.
July 20th, 2014, 7:41 pm
Post Re: Oil leak
That's a handy bit of lateral thinking; even got talcum powder in the shed, to use when fitting inner tubes to tubeless tyres... ;)
July 20th, 2014, 8:01 pm
Post Re: Oil leak
its an old one - used it to find where the water was getting in (non 2cv) take carpets out dust floor pan and wait for the teltales
July 20th, 2014, 10:20 pm
Post Re: Oil leak
Ken, quite right, I put the cowling back on today and saw that the sensor can be reached without the cowling being removed. Deep in there isn't it but much better than removing the cowling.
July 21st, 2014, 11:08 pm
Post Re: Oil leak
I was waiting for an order i placed with ecas before i took a stab at this, I'll update you all when i get a chance. Thanks for the help so far!
July 24th, 2014, 12:32 am
Post Re: Oil leak
I've spent the morning with a helicoil kit on the cylinder head oil feed, to anyone who hasn't stripped one yet they really are rather soft.
It was a major disappointment to solder up a hole in the oil feed pipe at the side of the road and then strip the thread for the cylinder head feed on reassembly. I went home on a rope.
July 27th, 2014, 2:02 pm
Users browsing this forum: No registered users and 177 guests
