View unanswered posts | View active topics It is currently April 30th, 2026, 12:12 pm
Reply to topic  [ 5 posts ]
 Oil sensor leak
Post Oil sensor leak
So here I am with more questions for the wise ones :)
My car has been leaking oil like a sieve, over the winter it got really bad before I noticed and it turned out the oil feed pipe had corroded, so I changed that, had problems with the thread on the crankcase because as per usual I over tightened it.. I rescued that and no leaks there at all, only it still has been leaving puddles everywhere.
Today I popped off the cowling to look, suspecting that actually my head needed re-seating. It turns out not, I re-torqued the head anyway, but the leak is actually coming from the oil sensor switch thingy.
My question is can I just tighten that up? Or is there a seal I can buy - or in fact does it need a new sensor unit with seal attached?
(I do wonder if I need a new breather too, and if that might help. Its not that old but I hear they don't last forever.)
July 12th, 2014, 2:41 pm
Post Re: Oil sensor leak
Well it seems the thing itself is duff. Took it out, cleaned the threads and surfaces, annealed the washer as I didn't have any to hand and replaced it onto the motor, same leak clearly from there. Tightened it up as much as I dared given the alloy block, no change at all.
So I ordered a new one and expect that'll sort it. Quite chuffed, it's been leaking for ages now and I really thought it'd be the head.
July 12th, 2014, 5:45 pm
Oil sensor get leaky when old, i suspect because of the plastics degrading of the heat or breaking because of the heat changes.
July 12th, 2014, 6:00 pm
Thanks. Yeah the plastic bit can be wobbled slightly in its housing.
July 12th, 2014, 6:08 pm
just fit another switch
July 12th, 2014, 6:41 pm
Users browsing this forum: No registered users and 77 guests
