View unanswered posts | View active topics It is currently May 1st, 2026, 12:09 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 29, 30, 31, 32, 33, 34, 35 ... 105  Next
 Make Your Own ....2CV.... 4x4
Deserves the 6000 views, brilliant thread!
Overly Ambitious Project
June 10th, 2014, 8:42 pm
Filling in the gaps.
Steering Column bearing mounting plate.
Tacked in place to see if it all rotates.
Clutch Pedal bracket (number 3)
June 12th, 2014, 1:32 pm
Paint always makes this look a bit better.
Versions of Steering column position.
June 14th, 2014, 6:33 pm
Chasing My Tail..
Because the steering column has been moved up the Bulkead it pushed the Steering Wheel nearer to the seat, such that my slim frame was a bit cramped.
Mk 2 - Steering Lock Mounting.
Mk3 - Steering Lock Mounting (a bit shorter)
June 26th, 2014, 6:11 pm
Been diverted to easier stuff that doesnt hurt the old back so much.
New Dashboard.
New Fuse Panel.
Wiring still to do ....
Front Indicators to wings.
Head/Side lights.
Side Repeaters.
Hazard switch.
Fit Rear Fog Lamp.
The rest is all done and working :D
On going Saga of the front suspension :( :(
As it is now...
TO DO.
Robust Front bump stops????
Figure out why the steering doesn't self-centre.
more Caster Angle may be required...
July 7th, 2014, 2:00 pm
Pete,
could be the camera angle, but there seems to be a fair bit of negative camber on the offside wheel, more than is on the nearside.
If that's the case, it would make the car pull to the left, iirc...
Ken
subarupete wrote:
TO DO.
July 7th, 2014, 2:42 pm
Hi Ken,
Looked like that to me, adds to my woes.
Quick measure, nearside 1deg offside 2.1 deg , with my Iphone :lol:. Using the flat part of the wheel centre...
Its now raining....
July 7th, 2014, 4:29 pm
Aaaah now I know at last where the heck a I-phone is for... :lol: :lol: :lol: :lol: :lol:
Is it running already on 1-2-Spark or is it also on the todo list....
p.s. self centering has to do with Caster not with Camber.. It doesn't like right anyway, Ken has a point there, but you noticed it already...
Think about a shop trolley wheel when giving Caster to it/lining it up.... then it can't go wrong.... :idea:
Otherwise looking superb ;)
July 7th, 2014, 4:41 pm
Todo list...
Camber, Caster, engine out ...12spark.. :lol:
July 7th, 2014, 4:50 pm
New bump stop, support bracket will bend before the chassis does, well thats the plan.. :o
July 12th, 2014, 5:20 pm
