View unanswered posts | View active topics It is currently April 29th, 2026, 3:23 am
Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Exhaust manifold studs
Post Exhaust manifold studs
Soo my exhaust manifold studs are just turning more or less freely. Apart from one which snapped off a while ago. It's blowing badly now, funny that!
Will it be possible for me to re-tap these holes to the next size up? Or is it a heli-coil job.
The reason I ask is because I'm happy with a tap and dye but never done a heli-coil so it'll have to go to the garage for that, probably. Although there's a first time for everything I guess.
July 4th, 2014, 8:22 pm
Post Re: Exhaust manifold studs
If you can get the studs out you can retap them to m8.
July 4th, 2014, 8:55 pm
Fantastic, thanks.
I wonder if that's been done before though, about ten years ago it went to the garage with a similar problem. I guess I'll find out.
July 4th, 2014, 9:36 pm
If the nuts on them were 11mm it was the standard m7, if they were 13mm they're m8.
July 4th, 2014, 10:03 pm
Yeah they are 11mm so that's all good. Thanks.
July 4th, 2014, 10:09 pm
Be aware that bringing them to M8 you have very little/no space between 13mm nut and exhaust manifault.....
July 5th, 2014, 3:12 pm
Thanks, good point. Maybe I'll do my first heli-coil then. It seems easy actually.
Have to remove one stud first which is snapped flush. Oddly not much of a blow on that side, it's the other that's gone fully tractor-ised.
July 5th, 2014, 9:20 pm
Try to weld a bolt to the stud, even what is left over of it, the heat will loosen it, so if you have half a decent weld you can loosen it..
or take a big nut M16 or so and weld the stud to it, try to release it then..... heat will do the trick.....
Nothing to loose there :lol: :lol: :lol: :lol: :lol: :lol: you can always drill it out if it doesn't work....
July 5th, 2014, 10:51 pm
That sounds very satisfying, I don't weld though so I'll have to try an easy-out.
July 5th, 2014, 11:54 pm
use a 25mm M8 "allen head" cap screw.
July 6th, 2014, 9:35 pm
