View unanswered posts | View active topics It is currently May 7th, 2026, 11:33 am
Reply to topic  [ 284 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29  Next
 LGY 275P Rises Again!
Post Re: LGY 275P Rises Again!
I'll be lucky Paul, doesn't even give it the time of day let alone give me a hand with it!!! I have to struggle on, on my own
Dyane 12 1976 (ish)
June 13th, 2014, 11:48 pm
The garage door has been opened and a few hours ( well a while anyway) might be spent having a play... Wish me luck :D
Dyane 12 1976 (ish)
June 21st, 2014, 5:09 pm
Ok. nobody else seems to do it...... Good luck..
June 21st, 2014, 7:15 pm
Good luck!!
June 21st, 2014, 8:00 pm
Cheers but it Just seemed to be too bloody heavy, and stuck it wouldn't budge!!
Hey ho there is always another day!! :roll:
Dyane 12 1976 (ish)
June 21st, 2014, 8:03 pm
I'm almost about to list it on eBay,
Managed to get engine parted from gearbox and rest on front of chassis, put the correct release arm spring that joolz kindly gave me, bolted back together and still the drive/driveshafts r locked up solid!!!! :evil:
Started to loosen the 4 engine/gearbox off yet again and slowly the driveshafts started to move again but with the background of an awful metal on metal noise!!!!!
Sounds like the pressure plate is rubbing on the inside of the bell housing, but why the hell is it doing that??
Gearbox is a standard 4 speed out of a GS and the clutch was supplied by rob at chevronics
The whole set up has been fine with the old 1220cc in, then I put this 1299cc I got from Paul aka nelsthebass and suddenly another fucking problem!!!!! :|
I've hopefully attached a couple of pictures, I know is hard to see when not in the flesh but to those in the know does anything look wrong????
Sorry pics ain't great!!!
Dyane 12 1976 (ish)
June 22nd, 2014, 4:41 pm
Are all G flywheels the same, or are there different thicknesses?
June 23rd, 2014, 4:18 pm
Gearbox input shaft looks to be cut off.
June 23rd, 2014, 5:50 pm
Online
GS Bellhousing?
June 23rd, 2014, 6:21 pm
Have I got an ami box not a gs one???
Dyane 12 1976 (ish)
June 23rd, 2014, 7:50 pm
Users browsing this forum: No registered users and 353 guests
