View unanswered posts | View active topics It is currently August 18th, 2025, 3:37 am
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
lpgo wrote:
Geert wrote:
Nice running engine !
Sounds so smooth ;)
Now Geert I think when I really let this engine run (with the exhaust as it is now) you can hear it over at your home.....
At 50 Km distance?
May 18th, 2014, 10:46 am
Geert wrote:
lpgo wrote:
Sounds so smooth ;)
At 50 Km distance?
If the wind is going into the right direction :lol: :lol: :lol: :lol: :lol:
May 18th, 2014, 10:57 am
Heres a little secret from me... I'm using the inner half of a bearing here, it makes a nice flat surface to connect to the engine. Perfect fit to the exhaust gaskets...
Next the double Dutch 2cv engine mounts (2 x 2 engine mounts) :lol: :lol: :lol: :lol: :lol:
It feels very very stiff, I think it will do the job
Because I have no flywheel at the moment I put the 1-2-Spark sensor and pickup at the front beltwheel
Trimmed also the adaptorplate to almost its final shape...
One thing I'm saving before I can start the engine... I need to weld some aloy valve cover
bolts housing..... After that it's new oil, filter and fire it up.....
June 17th, 2014, 10:58 pm
Re-aranged the left exhaust manifold a little and made everthing definitly.... I like the look of it...
June 18th, 2014, 10:43 pm
Great job ! Curious to heard the sound of this engine ! No doubt a magic melody ! 8-)
June 18th, 2014, 10:47 pm
Hope to fire it up within the next two weeks.....
Otherwise listen to this... the sound of my 2cv Turbo injection..
http://www.youtube.com/watch?v=5aTO2LkTkpM
June 18th, 2014, 11:05 pm
Like it 8-)
June 19th, 2014, 1:50 pm
Your a master of your own universe Geo, I luv the independent thinking. The bearing surface is a perfect application.
With the engine suspended at the front I imagine you will need a secure gearbox mount to stop the engine from doing front somersaults on heavy acceleration.
June 22nd, 2014, 8:41 am
First. You are thinking in the wrong direction....... it will do somersaults on heavy braking,
when accelerating it will be pushed furhter into the backmounts...
But I thought about that too, I will weld 2 washers (M10) to the (back) gearbox mount, to catch the gearbox bolts just like a Mehari 4x4 (backdiff) has too....
June 22nd, 2014, 9:32 am
Here a close up from my own 4x4, I hope you see what I mean "welding the washers to the engine-mount"
June 22nd, 2014, 10:03 am
