Page 1 of 1
[ 6 posts ] |
meshking
 Tie rod adjuster
Ken's post in setting the ride heights properly has forced my decision to do it properly on my drummer.
What tool do most people use? Graeme Seed doesn't make the tool anymore, and I don't really fancy spending £30 on the fancy ratcheting spanner at ecas.
| June 15th, 2014, 9:50 am |
Russell
 Re: Tie rod adjuster
Mole grips, if you're lucky a 9mm spanner or if the gods are really smiling on you they'll turn by hand.
| June 15th, 2014, 11:00 am |
poprodder
Joined: January 25th, 2014, 11:23 pm Posts: 134 Location: norfolk
I was lucky, mine turned by hand, everything on the car had been greased on a regular basis, looks horrible but nothing seized.
_________________ live life to the full, it can end so suddenly.
| June 15th, 2014, 1:30 pm |
AZS
Joined: December 22nd, 2013, 5:01 am Posts: 300 Location: Netherlands
Use 2 spanners size 9 at once to spread the load. If a mole gripe is absolutely necessary, i usually put them on the ring beside the spanner place (the friction weld?) to prevent the rest of the rod from being damaged. But if everything is okay, it should be possible to turn them by hand.
| June 15th, 2014, 3:07 pm |
meshking
They're a bit sticky, I'll just struggle on with mole grips. Thanks chaps.
| June 15th, 2014, 3:10 pm |
samfieldhouse
Russell wrote: Mole grips, if you're lucky a 9mm spanner or if the gods are really smiling on you they'll turn by hand. Always worked for me
| June 15th, 2014, 8:23 pm |
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 216 guests |
