Hildebrandt
 Re: Gear reduction idea!
Harley wrote: I don't fancy flipping the crown wheel everytime I want to engage low range! up
_________________ Best regards, Ulrik 2cv.Clinikken Denmark
| May 27th, 2014, 3:49 pm |
Rusty
Joined: January 12th, 2010, 10:33 am Posts: 193 Location: Koudekerk ad Rijn, Netherlands
Gave it another tought and suddenly remembered, My dad has a triumph spitfire, it has an overdrive fitted, never really looked at it but as far as i know it is also a planitairy thing to lower the enginespeed. If you'd use a 2cv4, low geared gearbow and fit 1 of those on each side, you'd be done....
_________________ bitten by the Citobug...
| May 27th, 2014, 7:10 pm |
Little Louis
Double reduction? So it spins backwards then forwards? A gear within a gear, within a gear - A gearbox version of inception.
| May 28th, 2014, 11:33 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
Mehari 4x4 ......
| May 29th, 2014, 9:25 am |
-niels-
You should use a double planetairy gear with a singel outerring, the wheels inside the second one will turn the driving direction again so it will go forward again.
| June 5th, 2014, 1:20 pm |
Pony
The problem as i see it is this
Gearboxes are about the 2nd most expensive part to make after the engine. most 4x4 use standard boxes with reduction box after Shit idea 2cv is one of the only cars built with an internal reduction already in place rev 1 and 2 gears are all reduced internally
Solution Re design the 2cv box with rev 1,2,3 a gears all available in normal reduction mode or extra low Then add 5th and 6th gears for a good long distance driving and economy (not reduced)
Easy just bloody deer about 5000 euro a box min quantity 200
ask Quaife i did!!
Oh and to add fun fit a 4x4 system to the lower part of the casing, Easy
| June 6th, 2014, 10:06 pm |
lpgo
I'm in!!
| June 6th, 2014, 10:12 pm |
Users browsing this forum: No registered users and 76 guests |
