View unanswered posts | View active topics It is currently August 19th, 2025, 9:21 pm
 brake fluid tank - 1981 Dyane 6
Post brake fluid tank - 1981 Dyane 6
Im loosing brake fluid, I think from the seals below my fluid resovoir. Im looking for a screw or bolt to remove the fluid tank, but cant find one. How does the tank remove from the master cylinder. Any help appreciated
pete
May 14th, 2014, 11:42 am
Post Re: brake fluid tank - 1981 Dyane 6
Just pull it off, some wiggling might help.
May 14th, 2014, 12:17 pm
As AZS already says, there are no screwes/nuts involved with these newer reservoirs....
just wiggle and pull....
Out is easy, in is a little bit tricky.....
take a good look is it really leaking at these connections????
Clean it up, make it dry take a good brake (you don't need to drive just hit the pedal for a minit or 2) :lol: :lol: and look where it is really comming from.....
May 14th, 2014, 12:33 pm
The reservoir needs to be pushed to the side, so that the bayonet fittings in its base are 'rolled' out of the rubber seals in the master cylinder.
A straight pull upwards is not advisable and isn't as effective as the sideways push... ;)
pete
May 14th, 2014, 12:34 pm
Thanks for quick replies, will have another look on Friday morning. To be honest Im grasping at straws as to where its coming from. If the car is left for a week or so the header tank is empty, nothing on the garage floor. The area below the master cylinder has a thin film of LHM on it so that was my first thourght. I have changed the front calipers and seals and checked the rear cylinders - all bone dry.
May 14th, 2014, 5:25 pm
Isn't the fluid container broken, they will break at the seams when older...
Put new seals into the leads going into the master brake cylinder also.
Did you take a good look inside the car??? Are you sure it doesn;t leak at that end where the rod from the brakepedal goes in??? They will leak there also....
May 14th, 2014, 5:39 pm
I had that one - lifted the carpet and there was a green swimming pool behind it :(
May 14th, 2014, 6:37 pm
never thourght of the rod. Thanks for that suggestion. I will look at that on Friday also. As the master cyclinder has been untouched for 30 odd years it may be easier just to do a complete change out.
May 14th, 2014, 8:19 pm
If that's the plan, maybe worth adding the bit I forgot earlier; refitting the reservoir back onto the master cylinder.
Using the appropriate brake fluid as a lubricant, pressing the reservoir straight down seems to work just fine.
May 14th, 2014, 10:13 pm
Do not forget that if are to change the complete unit the reservoir has to still come off as the master cylinder comes out from inside the car. Can be a fiddle.....
May 17th, 2014, 8:33 am
