View unanswered posts | View active topics It is currently April 29th, 2026, 11:48 am
 Throttle problem
Post Re: Throttle problem
If it is just relying on the carb jets (after changing pump) then I would clean all of them as it sounds like second throttle one is blocked.
February 4th, 2014, 6:07 pm
I had all end of issues on the second choke on the Beige Beast...you have to clean, clean and clean again the jets, make sure there is no crap in the bowls and fit a filter close to the carb to stop the bits from a failing fuel line....
February 5th, 2014, 12:05 am
Finally solved, swapped with the old carb I had lying around now working fine.
AKA: Will
April 26th, 2014, 5:28 pm
