View unanswered posts | View active topics It is currently June 20th, 2026, 12:20 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 105  Next
 Make Your Own ....2CV.... 4x4
Well it runs, steers, stops.
So major stuff done, tentative plans for Morvan.
However the car is under covers , at the moment the garage is full of furniture, so thats slows things a bit....
Plus its been cold and wet ;)
February 27th, 2014, 10:30 am
we are trying to sort out morovan
T shirts made
Tubs Ru and i are so far going
Any one else?
What about this monster of yours Pete only about 7 weeks to go!??
Could it do the monte impossible?
Pony
February 27th, 2014, 10:08 pm
Hi Pony,
Needs battery bolting down,
Some wiring,
Make a passenger set,
Wings bolted on,
Doors fitted, hinges, catches etc
All the glass fitted ....
Then it looks like a 2cv :lol:
Had a telcon with Paul T about tentative plans
cheers
peter
February 28th, 2014, 12:28 pm
As it has been such a nice day, uncovered the front :)
March 1st, 2014, 3:35 pm
Bit more done..
Inner parts of front wings need more trimming to clear spring cans etc ......
March 10th, 2014, 1:47 pm
Doors, Paint, Canvas clip-on cover for the rear door.
March 15th, 2014, 3:29 pm
Some comparison images...
Front Barbour 4x4
Front New 4x4
Rear Barbour 4x4
Rear New 4x4
Side Barbour 4x4
Side New 4x4
March 15th, 2014, 7:43 pm
Pete.
Have You heard about Ackermann -theory? Inner front wheel should turn more than the outer, if not, You loose grip on front wheel when turning...
Something like that
As it can be seen from the last picture of You car, it seem to be opposite, the outer wheel turn more than inner.
That can be a problem, it makes also qreat understeering, car "want" to go straight instead of turning...
If You want to have front axle like You have, the steering rod joints must to move much outward, outer than kingpin. On normal position with 2CV steering, the joint is inner than kingpin...
Hope You are thinked about this, if not, I'm sorry that didn't mention that before... :oops:
March 15th, 2014, 8:12 pm
Hi Jasu,
Ok on the steering, the arms have been altered with a lot more castor angle added, its first drive was ok but may need some more adjustment.
Cheers
Peter
March 15th, 2014, 8:31 pm
Maybe you could swap the rod ends side to side to counter that, if they fit within the wheel.
March 16th, 2014, 12:12 am
