View unanswered posts | View active topics It is currently November 20th, 2025, 5:48 pm
 Bump stops and MoT - what if they aren't there?
Post Bump stops and MoT - what if they aren't there?
So my rear bump stops on the 2cv have seen better days... can I just amputate them, accepting the risk of bottoming out on the wings?
Would that be MoTable?
January 29th, 2014, 5:24 pm
Post Re: Bump stops and MoT - what if they aren't there?
Not in my experience !
January 29th, 2014, 7:45 pm
It won't bottom out on the wings, I reckon the bumper and towbar will hit the floor first. If you make a good enough job of removing them the tester won't know they were meant to be there.
January 29th, 2014, 8:01 pm
Hi Sam. A missing bump-stop is not a reason for mot failure.
January 29th, 2014, 8:11 pm
The Shed had no bump stops just rusted stumps and never even got an advisory....
January 29th, 2014, 9:46 pm
Far be it from me to suggest doing something properly, but as your car is a bare shell off the chassis with no rear wings on, why not take the opportunity to repair the bump stops and replace the missing parts?
January 29th, 2014, 11:27 pm
Daras,
to be technically correct, the official wording is as follows.
"Note: a missing bump stop rubber is not a reason for rejection."
Also, since the bump stop mounting bracket lies within 30cm of a seat belt mounting point, if corrosion of that bracket had affected the strength of the inner wing, that could (or should?) be a reason for failure.
Those rear bump stop brackets are very efficient rust traps, if left to their own devices... :roll:
Edit; as Russell ( has already) said. ;)
January 29th, 2014, 11:46 pm
This is my worry.
Are you volunteering?
January 29th, 2014, 11:51 pm
:shock: Just seen the price of the repair panels.
January 29th, 2014, 11:52 pm
no prob sam bung it through
mind u, its important to get a 2cv mot at a specialist garage not quickfit wankers
mine passed with rust by the rear seatbelt mounts by unbolting the rear seat belts and removing the seat
January 29th, 2014, 11:54 pm
