View unanswered posts | View active topics It is currently November 20th, 2025, 2:58 am
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3  Next
 alternators and gearboxes...
Post Re: alternators and gearboxes...
You don't need to bypass the external reg to use an internal-reg alternator. Whichever of the two regs is set to a lower voltage will "win".
If the alternator's putting out 14.5v, and the external reg's set to 14.0v, then the external reg will kick in, and the battery will see 14.0v.
If the alternator's putting out 14.0v, and the external reg's set to 14.5v, then the external reg will just pass it straight through, and the alternator will see 14.0v.
January 22nd, 2014, 9:20 pm
visa alternators ( 650 ) just bolt in no problems - yes you can bridge the alternator plug with a low wattage bulb in a standard teltale warning light thats what ive done on Vickis mobile gin palace and internet node
January 22nd, 2014, 9:33 pm
I'm led to believe that the pulley V profile on a Visa is different to a 2CV pulley profile so the belt will not sit snug on the pulley. best to check or your belt might not last as long and be likely to slip
January 27th, 2014, 9:43 pm
Kit,
someone leading you up the garden path, again? :roll:
January 27th, 2014, 10:02 pm
nope works perfectly "out the box"
January 28th, 2014, 7:22 pm
"Some" say to pulley taper is different. ..
All I know is I have a pulley I chopped down, now with ripped pulleys on it, on my visa motor... but I ran it on the 2cv for quite a while...
are the tapers different?
January 29th, 2014, 4:24 am
Nope.
Too many 'armchair mechanics' around, with plenty of theories but very clean hands... :lol:
January 29th, 2014, 8:58 am
Haha, thx Ken.
That one had me worried for a while!
Cheers,
January 29th, 2014, 10:18 am
scared of the dark
Fit it, if it works, it works.
Thats how I got 70A for £30 :)
Some previous cars:
January 30th, 2014, 4:21 pm
lovin' the snatch
Andy, a 70A that fits? AX, Saxo or similar? i've seen some early saxo ones which have a similar pulley and similar fittings which were 70A i think!
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
February 1st, 2014, 11:23 pm
