View unanswered posts | View active topics It is currently November 20th, 2025, 7:58 am
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 6v fuel gauge on 12v
Post 6v fuel gauge on 12v
So i have a 6v fuel gauge I'd like to use on a 12v car. If I wire it up with one of these, will it work as prescribed?
http://www.ebay.co.uk/itm/DC-DC-Converter-12V-Step-down-to-6V-3A-15W-Power-Supply-UK-SELLER-672-/350950348467?pt=UK_Computing_Other_Computing_Networking&hash=item51b64556b3
http://www.ebay.co.uk/itm/DC-DC-Converter-12V-Step-down-to-6V-3A-15W-Power-Supply-LONDON-UK-SELLER-20-/111251612694?pt=UK_Computing_Other_Computing_Networking&hash=item19e71ce416
January 26th, 2014, 9:03 pm
Post Re: 6v fuel gauge on 12v
Could you not wire a resistor in the feed line?
January 26th, 2014, 10:33 pm
Apparently yes but I wondered if a proper 6v fees would be more stable.
January 26th, 2014, 11:47 pm
A stablised 6 volt supply is the only option; a single resistor won't work because the current drawn by the gauge and sender varies with the level of fuel.
January 27th, 2014, 12:26 am
or just fit a newer dash then youll have a working fuel gauge AND mph speedo :P
January 27th, 2014, 9:03 am
Cheers for that :)
Yeah but where's the fun in that :lol:
January 27th, 2014, 11:06 am
When I changed my '63 AZU to 12 volt, I left fuel gauge and sender the same except for the dash lamp. Works perfectly. Note, there isn't a stabilised supply, just the alternator regulator. The only small problem I have is that the speedo reads 10 kph fast.
January 27th, 2014, 2:52 pm
There is quite some debate as to wether 6v gauges will work on 12v, the VW forums are full of it...
January 27th, 2014, 3:04 pm
Why not try it :o
Then there is no debate :D
January 27th, 2014, 4:43 pm
Sam, you literally just need 2 resistors to step 12V to 6V in the form of a voltage divider.
So your Vin is 12V... The V out is controlled by the ratio of the two resistors.. put simply Vout = (R1/ (R1+R2))*Vin
Basically to drop the voltage by half you need all the same resistor values...Using 150Ohm resistors Vout = (150/300) *12 = 6
January 27th, 2014, 9:20 pm
