View unanswered posts | View active topics It is currently February 3rd, 2026, 11:55 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
This maybe a stupid question but as i have put the battery into the rear i plan to just earth it onto the chassis and earth the gearbox in the same way, is this ok to do? It's how i would run this setup on a vw.... unless there is a reason why it must be earthed on the gearbox...
Thanks Ben....
Now in the process of chopping down the front arms, really not as bad as i expected.. 60mm each side.. :mrgreen:
www.evilbens.blogspot.com
January 19th, 2014, 8:07 pm
I should think it would be fine - all your lights etc are earthed to the body which goes back to the gearbox.
January 19th, 2014, 9:51 pm
Wire from battery earth to chassis and from chassis to gearbox is ok... This is how it's done on a Sahara (with the rear engine) and this is how I did it with my Ami 4x4 (batterybox in the rearwing)..
You can make a wire directly from gearbox connection to the groundpin at the firewall (e=where all earth wires come together).
However try to make the + wire as thick as you can otherwise a lot of current is lost over the distance.....
and your starter engine will be poor.....
Geo
January 19th, 2014, 10:01 pm
Thank you both, great one less hole i have to drill....
January 20th, 2014, 9:42 am
As already posted re using heavy wire,I'd go for the same as used for battery cable and make sure it can't chaff on anything,to avoid any risk of a shortout and a fire :-) MGB's function ok with their batteries in the boot and they had a pair of 6volt,so more wire !!!
January 20th, 2014, 11:40 am
wow, liking this. just spent 1/2hr reading whole thread.
some outstanding fabrication work there. nice one.
looking forward to more progress.
cheers chris.
live life to the full, it can end so suddenly.
January 30th, 2014, 11:23 am
Thank you Chris... its been a lot of fun so far...
January 31st, 2014, 9:56 am
Well it had to happen the start of the year and work got in the way and slowed progress on my Dyane..
At last it was time to cut down the front arms and rotate the king pins....
May 18th, 2014, 5:20 pm
After working out that the wheel needed to sit in the middle of the wheel arch 60mm was the amount needed to be removed....
All smoothed off back to the factory casting.....
May 18th, 2014, 5:23 pm
Pie cut back down to be a tight fit back on the king pin and rotated and lined up back on the car...
Then the pie cuts welded and fully seam welded back into place....
May 18th, 2014, 5:27 pm
Users browsing this forum: No registered users and 792 guests
