View unanswered posts | View active topics It is currently May 7th, 2026, 12:32 pm
Reply to topic  [ 87 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 say hello to "Arfur" the azu.
Post Re: say hello to "Arfur" the azu.
So how come you can hand crank a car with a dead battery
January 9th, 2014, 7:53 pm
Because the 'dead' battery may just have enough juice to power the ignition system. If it is totally flat then you don't stand a chance.
Very old cars and motorbikes had magnetos which generate the electricity for the spark. You can start them without a battery.
John Jordan
January 9th, 2014, 9:02 pm
In My experience you need at least 8v in there to have any luck. With a DEAD battery reading nothing on a multimeter) even rolling down a steep hill over about 100m won't get you anywhere.
January 9th, 2014, 10:47 pm
You can make a 2cv run on a 9 volt battery (little rectangle block battery) I once did that on points, will work with my ignition too I'm pretty sure, however don't hit the brakes/lights or its gone....
and you need to take the connection of the dynamo of.... (I guess but I didn't remember doing that.)
January 9th, 2014, 10:54 pm
That's pretty cool 8-)
January 9th, 2014, 11:48 pm
Exactly - I rolled down 10 km at an average of 7% in 3rd gear trying to start and there was nothing.
Only a boost from a 12volt booster got me home in stages.
But now I have fixed my dynamo there is no stopping me :)
January 10th, 2014, 9:41 am
thanks for that guys, I tried it with a battery but still no joy, probably the plugs, and all the earths need shining up. anyway the blokes pickup has arrived so i´ll have to be working on that for the next month or so..the thing is massive you could get the azu on the back of it!!
January 11th, 2014, 7:10 pm
Get rid of that plastic chair and it could be a calendar shot!
January 11th, 2014, 7:48 pm
thanks jacques ;)
pleased with my find today
pulled out some very slick seats with headrests from a dyane in the scrap yard today.
the pair along with a set of seats for a mercedes fintail, and a mercedes headlight for 100€
bargain
January 20th, 2014, 7:55 pm
guess who´s a happy bunny !!!!
ME ! :D :D :D
arfur is alive.. the new old starter motor arrived today, and after a bit of messing around with cables and dodgy earths it started spinning on the 12 v battery. than after reminding myself of geos advice for starting sidney, I did the same thinng with the cable from the distributor to the coil, and sparks started to happen.
then with help from my daughter and a couple of tubes it started cranking up. now it sucks from the bottle and stays alive really well.
I let it run for a while to warm up and have just changed the oil now also.
no exhaust on it so sounds like a tractor but frankly even then it sounds smooth and solid
vid to follow
happy !
January 25th, 2014, 5:47 pm
Users browsing this forum: No registered users and 375 guests
