View unanswered posts | View active topics It is currently August 13th, 2025, 9:06 am
Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 say hello to "Arfur" the azu.
Post Re: say hello to "Arfur" the azu.
looks like a real van now ;)
December 9th, 2013, 8:47 pm
Absolutely fabulous find. I look forward to seeing another amazingly quick turnaround.
December 10th, 2013, 10:57 am
ok so looking into the bad stuff now!, moved the car inside (its very foggy here during winter, so not good for unprotected tin.
undercoat on some of the rear interior to start sealing stuff.
rot in ther front floors as seen and then I discovered the suspension tube snap! has anyone ever seen this, the suspension still works fine and looks normal, but the tube has sheared in half!..I don´t suppose there are any quick fixes are there?
theres going to be a fair bit of welding on the front half of the chassis also
heres the pix
ps trip I´m near agramunt in lerida, about 150km south of the pyrenees
December 10th, 2013, 5:18 pm
I really like the paint job :) if you could preserve it that would be great
It's easy to make new pots for the suspention and for its age the 2CV look great :)
December 12th, 2013, 12:48 am
yes vasil. I´ve sourced some matt clearcoat with antirust component inside, its very slow to dry as it needs to be very sticky without primer..we´ll see how it looks next week, as at the moment the bodywork is like a sponge for greasy hands and dirt!
December 12th, 2013, 1:21 pm
sig,
that suspension canister didn't snap, it was cut; most probably a quick and dirty way of dealing with a broken tie rod or spring. ;)
December 12th, 2013, 1:34 pm
cheers ken, the innards seem to be ok, I guess just a new outer can should fix it no?..oh and those 2 44mm spanners that everyone moans about.
another question, the starter seems to not work, its very still and seems to short out when attached to a 12v battery.
I´m wondering if a 12 v starter would be a good upgrade as I have to get another.. (if I convert to 12v, the money I save on a cheaper battery can go to the starter?..but then I suppose you´re all going to say the teeth are different on the starter for the differnt flywheels??)
if I stay with a new 6v starter can I upgrade the rest to 12v? and is it worth putting one of those electronic ignition thingies on?
help please??.
meanwhile been digging shovel loads of soil/oil mix off the engine and nut shells from everywhere else., the inner floor is coming along also but I ran out of welding gas..it´ll be stainless again like sidney...but no channeling this time.
December 14th, 2013, 3:13 pm
on the operating table!! :o Image
December 16th, 2013, 8:18 pm
That is a great workshop - I wish I had never filled in my inspection pit when I moved here, but at the time I didn't think I would ever need it. Times have changed.... damn!!
December 17th, 2013, 11:10 am
Great workshop indeed :)
December 17th, 2013, 9:15 pm
Users browsing this forum: No registered users and 15 guests
