View unanswered posts | View active topics It is currently June 19th, 2026, 7:51 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 65, 66, 67, 68, 69, 70, 71 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
I do not pocess a windows computer..... Does this cause any issues? I only have MAC
December 9th, 2013, 11:50 pm
Post Re: 1-2-spark
Tripyrenees wrote:
I only have MAC
Me too - but you don't need to fanny around with settings, you can 'plug and play' I believe :)
December 10th, 2013, 2:49 am
Post Re: 1-2-spark
Sam that is true....
December 10th, 2013, 8:34 am
Post Re: 1-2-spark
but if you put it in any other vehicle, other than A-type 2 cilinder, you almost surely will have to 'tweak' the settings!
bitten by the Citobug...
December 10th, 2013, 8:48 am
Post Re: 1-2-spark
This will be for a 4 cylinder with a distributor, so that should work with the one from the 205.
December 10th, 2013, 10:34 am
Post Re: 1-2-spark
yes I understuud that, but every engine (even if they are the same type) will have different optimal settings, also every engine (especially if it is a different type; manufacturer) will have a different point where it will start pinking; detonating (not sure if it is the correct word)
so if the 12-spark isn't set for your car, it will have to be tuned (at least this is my opinion, but Geo will be able to confirm if this is true)
greetzzzzzzzzzzzz
December 10th, 2013, 11:22 am
Post Re: 1-2-spark
You live in Voorschoten..... I lived there for 5 years in Piljstarpad. Small world.
I need to find a cheap crappy Windows laptop then (lots to choose from :lol: ) - any ideas :?:
December 10th, 2013, 11:50 am
Post Re: 1-2-spark
My ignition will run out of the box, but at your Simca it is tricky so the best would be to tune it with a laptop.... if neccecary. You can put it in and when it runs well leave it (check your coil if it doesn't get hot) and check for pinking/overheating the engine.
You can always buy a laptop afterwards if you need the feel for tuning.
The same story for the M4 engine. But when using a black 2cv coil or yellow Harley coil you don't need to check the coil.. Just check on pinking, or overheating the engine (do to much advance).
December 10th, 2013, 1:12 pm
Post Re: 1-2-spark
Just got to get my head around the sensor pickup.
Do I need to weld a metal tab onto one of pulley wheels and then place the sensor to pick up this metal tab. How does the sensor work?
Sorry for being a bit thick here.
December 10th, 2013, 8:34 pm
Post Re: 1-2-spark
Yes you need to weld a metal tab onto one of the pulley wheels, but it has to be at the crankshaft, otherwise the speed isn't right. The VR sensor is a sort of dynamo, when the pickup passes the sensor a litlte current is made by the sensor and this is send to the chip....
Speaking in your therms it is like a bicycle speedometer, a tab is attached to the a spoke the sensor to the fork............. :lol: :lol: :lol: :lol: :lol:
Take some pictures of the engine and I will look at it....
December 11th, 2013, 6:36 pm
Users browsing this forum: No registered users and 213 guests
