View unanswered posts | View active topics It is currently July 7th, 2025, 8:51 pm
Reply to topic  [ 83 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Oil breather ECAS
Post Re: Oil breather ECAS
8.5:1
Let me be very clear. I'm not criticizing the oil breather sold by Roy. From memory the oil breather is made by Carfix in the Netherlands. I may be wrong
http://www.carfix.nl/start.html#/Producten
December 8th, 2013, 3:27 pm
Online
Swap the breather from a car thats good?
December 8th, 2013, 4:01 pm
I'm going to recondition an old buggered breather using this new kit from Burton
http://www.youtube.com/watch?v=R_5rUwyVHg4
December 8th, 2013, 4:44 pm
2CViking wrote:
Bart there is no blowby OK?
Lets move on.
What is the solution?
then all you can do is substitute the breather and see what its like with that?
( did you ever do a compression test and what were the results? - in numbers rather than "good")
EDIT - page 1 140 and 150 psi ;)
December 8th, 2013, 4:48 pm
Page one my dear :mrgreen:
December 8th, 2013, 4:53 pm
yeah i forgot - its ben goin on a while :+
December 8th, 2013, 5:04 pm
No, Carfix is but an wholesaler.
Has the lid got only 3 holes in it between the 2 threads? Some 3 hole items were troublesome.
2CViking wrote:
8.5:1
December 9th, 2013, 12:56 pm
Have you checked the small pipe from filler to dip stick - could it be blocked?
December 9th, 2013, 1:58 pm
Also is the oil cooler ok? I drove 4 up with luggage to San Sebastain in Spain at around 110kph all the way and the oil was reading 95-100 deg C (outside tekp 26 deg C) 700kms - only stops for petrol and food. My ECAS filler still looks like new inside and out. To melt the paint from the inside the oil must be getting very hot......
December 9th, 2013, 5:54 pm
2CViking wrote:
8.5:1
All our stock has 4 holes :roll: What is the problem Roy?
December 9th, 2013, 7:54 pm
