View unanswered posts | View active topics It is currently August 8th, 2025, 7:38 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 190, 191, 192, 193, 194, 195, 196 ... 400  Next
Took the cover off mine and started it up - First time in 2/3 weeks
Started second turn of the key :D
1988 2CV Special
1969 Singer Chamois
November 2nd, 2013, 8:23 pm
Shame on you :lol:
November 2nd, 2013, 9:12 pm
If it's outside you'd be better off not covering it.
November 2nd, 2013, 10:01 pm
That's always been my view, never even covered my bikes that were kept parked outside,as things tend to sweat and stay wet under covers, also you can get discoloration on your paint work from contact with the cover. Even some garages can cause your car to sweat, worse if you have used your car on salted roads, this should be washed off as soon as your able with cold water. Not nice in the winter but saves your car/bike rotting away before your eyes. I open my windows on dry days to air the car out and lift the rubber mats out to keep her as dry as possible inside,not easy with a 2cv. :lol: :lol: :lol: :lol:
November 2nd, 2013, 10:23 pm
Watched it surrounded by Chinese businessmen & government officials as they poked & prodded it during a fag break. They were probably wondering why on earth anyone in the UK would drive the sort of thing they could only have dreamed of thirty years ago if they were lucky & privileged enough, but now wouldn't give house room to in modern China.
November 4th, 2013, 9:21 pm
Replaced the one corroded headlight reflector with the one from a headlight that chewed brick ,which I'd kept. A quick dose of heat gun to get them apart then stuck it back with silicon,job done :-)
November 5th, 2013, 7:45 pm
Took a run up to Norwick Beach this morning. It's a glorious sunny day in Shetland. :) grill muff now in place as it was -1 at half seven last night.
November 6th, 2013, 4:54 pm
Took Gerty the AZAM for it's for it's MoT which it sailed thru with the same advisories as last year :lol:
Better than last week when I smacked into a C1 which did sumat stupid in front of me :oops: Hey ho.
Mike
November 7th, 2013, 12:24 pm
And I thought I was the only one with a 2cv called 'Gerty' :mrgreen:
November 8th, 2013, 10:52 pm
Finally sorted my floppy indicator switch out,which dispite however tight the clamp has been tightened. So having epoxyed the mounting plate into the switch body, it now nice and firm result :-)
November 8th, 2013, 10:58 pm
