View unanswered posts | View active topics It is currently June 20th, 2026, 12:04 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 105  Next
 Make Your Own ....2CV.... 4x4
Geo's description is right, its just his words...
........but a Road test will show how good the centering works.
September 20th, 2013, 7:38 pm
Sorry Pete, in Dutch it would be a peace of cake to explain what I want to say, but in technical English it doesn't make much sense, but I think you are getting it, the only thing is when the car will dropp into the springs for instance landing after a jump your centering will be gone but on a normal 2cv it will get stronger, just warning you but you understood that already....
Again it's a nice piece of engeniering out of your hands (I hope)..... looks great, will be a beast driving it off road.... I like it a lot.....
September 20th, 2013, 7:52 pm
volkwagen beetle frontaxle solution to overcome variable Castor-angle.....
and here the same solution 4x4 dutch army truck (goolgle daf 328 or daf 126)
b.t.w. mentioned this about 20 pages ago......
September 20th, 2013, 8:41 pm
Easier Job Today The Roof Joint.
Roofbar is not straight because of adding the extra width.
Local Engineering shop has a hydraulic bender, got this channel bent up..
Inside View
Top View
September 21st, 2013, 4:37 pm
Moved the brake pipes so that they don't foul the Hand-Brake cables.
Fitted Fuel Tap and Filter.
Repaired the Fuel Sender.
September 26th, 2013, 2:47 pm
Front Suspension Problems!
With the suspension on full compression, the steering tie rod would hit the steering column.
Solution was to rotate the rack clockwise in the saddles and put a bend in the tie rod.
Still have problems on full lock!!!!!!! with chassis getting in the way.
October 28th, 2013, 1:00 pm
I can't see where the chassis is getting in the way but it's hard to tell what is what in there!
I'm very impressed with your creation though, your a free thinker that's for sure.
October 29th, 2013, 1:06 am
A long tradition of free thinking on these islands... :lol:
http://www.britishpathe.com/search/quer ... playlist/1
October 29th, 2013, 2:16 am
Thanks guys.
Another pic
Full Lock, Full compression
October 29th, 2013, 11:19 am
How are you getting on with this, Pete?
February 26th, 2014, 10:01 pm
