View unanswered posts | View active topics It is currently August 13th, 2025, 11:31 am
Reply to topic  [ 115 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 12  Next
 Aussie' Kermit
Post Re: Aussie' Kermit
Your throttle is it before or after the compressor???
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
October 22nd, 2013, 9:33 am
Before.
October 22nd, 2013, 9:40 am
Had to order some different spark plugs today as the standard ones protrude to deep for the twin spark side, hitting the valve...
My mate just sent me this pic of the injector bungs welded in place 8-)
Progress!
October 23rd, 2013, 9:23 am
Hey Harley just a quick question, where did you get your twinspark heads from??
PP or did you make them yourselve???? And how is the problem solved for shorttening the lower stud??? I like the idea of twinspark now it is possible to drive it with my ignition.... Hope to get some more horsepower with twinspark...
October 23rd, 2013, 12:22 pm
:twisted:
I had the heads machined locally by an drag racer engine legend, he has since retired, cost was $1000.00AUD and 18months it took him to get around to doing it. I'm very happy with his work, I remember him saying he had another idea of how he would do it differently next time but I can't remember now...
I did have a diagram a Horst the German megasquirt Ami owner did, I believe he machined his own twinspark using simple tools.
The lower head stud is replaced with an 'Unbrako' bolt which sits just in front of and below the spark plug, it is accessed through the tappet are via a welch-plug type unbrako bolt. Easy :D
I really want this on the road! 8-)
October 23rd, 2013, 2:43 pm
The shorter spark plug worked a treat, in this pic it is the lower one, i don't think t is a very common type though...
Here are some pics of how we get around the shortened cylinder head stud.
You can see the threaded access hole with the unbrako nut on the side.
I've searched high and low for where I placed the by-pass valve I got off Ebay... fark-nose where it is... :evil:
October 25th, 2013, 4:37 am
Looking great but I think youy really don't need the hole in the rockerchamber to let the stud trough, otherwise it looks very clever ingenering to me.....
will send you a pm. in the weekend with payment details for 1-2-spark..... Do you have a connecting cable for megasquirt (db9 to PC) then you don't need mine...... and can I keep 2 coils and 2 coil-leads???
October 25th, 2013, 7:29 am
Looks very clever, like it.
October 25th, 2013, 9:40 am
Yes you can keep 2 coils and leads, I'm expecting another set (6) coming soon, if they arrive in good order you can keep the four and just post me 4 leads back, you got 8 leads correct? They should arrive in 2 weeks...
No rush no stress, ok!?
I guess you can get away with no access hole if you use a short head stud instead if a bolt, I can't get that bolt in on the angle without it...
Yes I have a connection cable.
October 25th, 2013, 12:31 pm
Why not a real stud and put a nut on it......
October 25th, 2013, 2:22 pm
