View unanswered posts | View active topics It is currently August 14th, 2025, 4:10 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
The rear is all welded into place and the box section used to set the new position of the shell cut out..
www.evilbens.blogspot.com
October 18th, 2013, 7:22 am
Starting to look less sorry for itself ...
October 18th, 2013, 7:24 am
The floors still need joining to the sills but i want to get the front bulkhead sorted first...
October 18th, 2013, 7:27 am
So onto the bulkhead, after folding up the lower plate this was seam welded into place and the centre section of the toe board welded in next....
October 18th, 2013, 7:34 am
A closer view .... i have ordered a steering UJ off the internet ready to sort the steering out, it will now bolt together this side of the toe board so a bigger boot/seal will be needed..
October 18th, 2013, 7:40 am
Time to template the outer section of the toe board...
October 18th, 2013, 7:43 am
Then swooped into steel and lined up and tacked in, hopefully by the end of the weekend the front should be done...
October 18th, 2013, 7:45 am
A week since your last update - this must be nearing completion, surely?! :P
October 25th, 2013, 8:07 am
No...... not yet Neil, the body is back off and upside down to weld the sills and cut and remove the old overlapping metal from the rear inner wings, the front of the sills need some rust repairs plus the new boot floor is going to need some ribs on the underside...
The good news is the new chassis from Roy at Ecas has turned up and a managed to get a very cheap secondhand air system for it too...
Photos to follow, going into work to carry on :D
October 26th, 2013, 8:09 am
The front toe board is all finished...a little bump was needed for the gearbox mount...
October 27th, 2013, 11:15 am
