View unanswered posts | View active topics It is currently June 19th, 2026, 11:56 am
Reply to topic  [ 429 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Before I forget here are some pics of a Dutch Beamer conversion......
Exhaust over the engine, making sort of heating system with it...
Just like I want to do...
It's easier afterwards to fit 2 turbo's (just for the record I'm already happy when the standard beamer will work)...
October 10th, 2013, 10:09 pm
Neat setup, I like the cowling he has made up, and the addition of the balance pipe in the exhaust on that last pic 8-)
It's had to tell what all that plumbing is doing running to the back rh corner then looks like an inlet near the exhaust...?
October 11th, 2013, 3:17 pm
Harley, I presume the idea is to get some cool air in the engine with creative sewer-plumbing pvc ...
October 11th, 2013, 10:32 pm
Today I fitted the mockup adaptorplate to the engine. Made a device invented by Joolz
a M8 centerpoint so I could easily point out the holes in the wood.
I left the plate as big as possible........ cut off is easy cut by ??????
some pics of the day..
Next step is to join the gearbox.... this will take a week or two because some milling is needed....
October 14th, 2013, 10:51 pm
looking good, I have started a cad drawing for my plate but need to measure the engine holes, Only just back from japan working so been a little delayed. I have the bmw gearbox in the boot of my car so can use that to measure hole centers.
October 24th, 2013, 5:52 pm
Online
I have some (QCAD.dxf) drawings for Plate and Flywheel adaptor for A MotoGuzzi conversion.
Useful for all the 2CV dimensions.
PM or email.
Cheers
Peter
October 30th, 2013, 11:43 am
So heres the plan how I do the line up between BMW engine and 2cv gearbox.....
I have a bar (25 mm Axle-steel) and at 1 end it is turned down in a lathe, so it is only 5.7mm widht.
In the Beamers crankshaft theres also a hole of 5.7mm so the bar will exactly fit in the hole lining up the gearbox with the engine...
In the gearbox I have 2 25/52mm bearings and ive modified the hole of the ingoing shaft (took out the tube which sits in there) suprisingly it is 25mm now...
So in my brain this is going to be perfecty lined up when the axle goes through the whole gearbox into the crankshaft....
Image...
Need some bolts and nuts, so somewhere this week there will be a interracial wedding in my garage :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Suggestions (why this won't work) are welcome...
November 17th, 2013, 7:27 pm
Geo
Maybe this build might help - Dec 17th onwards
Bottom of pages go to next month onwards
http://www.11tinkers.com/Brooklands_Dec.html
Chris
November 17th, 2013, 10:48 pm
Today I spent some quality time with my Beamer..... engine...
November 23rd, 2013, 9:52 pm
been working on this any more lpgo? Be good to see another BMW a-series zooming around!
January 11th, 2014, 3:57 pm
Users browsing this forum: No registered users and 193 guests
