View unanswered posts | View active topics It is currently November 20th, 2025, 6:48 am
Reply to topic  [ 10 posts ]
 Engine missing under load
Post Engine missing under load
All of a sudden, the 602 was missing under load, but never stalled - intermittent.
First thoughts - ignition - contact breaker.
Then was it the condensor ?
Or was it the coil ?
Could it be the petrol pump
Perhaps a blocked jet ? Yesterday, for no other reason than it was easier to take the lid off the carb, I found a big lump of paint swimming in the fuel bowl. Cleaned it all out, removed all jets - didn't find any more rubbish. A test run went all OK and today another run of 40Km and all was well. I hope that is the end of it.
BobH
September 6th, 2013, 6:56 pm
Post Re: Engine missing under load
Ughhh Back to the drawing board. One day of purrrfect behavior and the next day back to the old problem - missing under load. So Me thinks its time for a new condenser ?
September 9th, 2013, 8:28 pm
I would be checking where the first lump of paint come from first and clean the fuel system.
September 9th, 2013, 8:33 pm
sounds electrical :?: coil or just plugs / ht leads
September 9th, 2013, 9:51 pm
Fuel strainer on the carb.
I've Been Wrong Before.
September 9th, 2013, 10:07 pm
Looked at the points, which were sparking when opening and closing. Visited local Citroen garage and bought new points and condenser - seems OK now and no sparks at the points. Dare I say FIXED ??
September 11th, 2013, 8:23 am
Now the starter switch has short circuited - permanently closed.. Doooh!! Oh well, back to using a light switch again.
September 18th, 2013, 8:57 am
D'oh! ...
September 20th, 2013, 6:04 pm
the origional starter key switch is prone to packing up- if its knackered make sure you disable the steering lock part of it
September 20th, 2013, 9:43 pm
Or just use the key as i did so its still semi secure
September 21st, 2013, 9:14 am
